LS6 intake with NW throttle body
Old Jan 20, 2007 | 10:29 AM
TheLS1Kid's Avatar
Default LS6 intake with NW throttle body
i have been trying to find the specs on the size of an ls6 intake opening but have had no luck. i was wondering if a 90mm NW throttle body will fit on an LS6 intake? thanks in advance.
-Mike
Old Jan 20, 2007 | 10:35 AM
MeentSS02's Avatar
Kleeborp the Moderator™
No it won't.
Old Jan 20, 2007 | 11:00 AM
TheLS1Kid's Avatar
appreciate it man, thanks.
Old Jan 20, 2007 | 11:36 AM
MeentSS02's Avatar
Yep...you certainly aren't the only one to wonder this. It'd be nice to get around having to buy the FAST 90mm intake that you need to bolt the NW 90mm up, but as of right now, you really can't. TPIS modifies the LS6 intakes to fit a larger throttle body, but again, that's just more money.
Old Jan 20, 2007 | 11:51 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
What intake are you rockin' Steve?
Old Jan 20, 2007 | 12:56 PM
TheLS1Kid's Avatar
just curious, how big is the opening in "mm" of the LS6 intake anyways? i cant find that spec anywhere.
Old Jan 20, 2007 | 01:07 PM
TheBlurLS1's Avatar
That's what she said...
78mm
The 90mm stuff also has a 4-bolt pattern, where the LS1/6 manifolds have a 3 bolt pattern.
Old Jan 20, 2007 | 01:12 PM
TheLS1Kid's Avatar
thanks man
Old Jan 20, 2007 | 02:35 PM
MeentSS02's Avatar
Stock LS6...undecided on which direction to go with my car, so it stays for now.
Old Jan 20, 2007 | 03:55 PM
cablebandit's Avatar
i know someone who has his tpis ls6 intake with 90mm tb for 500.00
Old Jan 21, 2007 | 06:06 AM
b1er's Avatar
Jesus Jerry....you getting rid of that thing already?
Old Jan 21, 2007 | 08:16 AM
nope...gonna make 1000rwhp thru mine
Old Jan 21, 2007 | 08:46 AM
00BlackSS's Avatar
Originally Posted by TheBlurLS1
78mm
The 90mm stuff also has a 4-bolt pattern, where the LS1/2 manifolds have a 3 bolt pattern.
um.......ls2 is a 90mm opening and is a 4 bolt patteren
Old Jan 21, 2007 | 09:20 AM
TheBlurLS1's Avatar
I meant LS6.
Old Jan 21, 2007 | 07:45 PM
00BlackSS's Avatar
I meant LS6.
ahh i got ya
Old Jan 22, 2007 | 12:41 PM
v8hunter's Avatar
I'm pretty sure that it is 75mm.
Old Jan 27, 2007 | 07:40 PM
TonyG's Avatar
Whats the size for a LS6 Intake?? 75, 78, or 90???? I too would like to know what the best upgrade for my 02 SS TBody would be?
Old Jan 28, 2007 | 02:15 AM
DJMRTS's Avatar
Actually there is a solution to put a 90mm TB on an LS6 manifold:
http://www.tpis.com/index.php?module...ed+LS6+Intakes
Old Jan 28, 2007 | 09:25 AM
2000TransAmWS6's Avatar
your best option is a stock ported throttle body, unless you want to buy an aftermarket intake manifold
Old Jan 28, 2007 | 09:32 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Agreed.
