Ok, next rookie question
Old Jan 20, 2007 | 02:08 PM
longboard's Avatar
Default Ok, next rookie question
1) Shouldn't the crank pulley come off easily with an air wrench? 2) Should the engine turn over with a socket on the crank pulley and a long handle?
Old Jan 20, 2007 | 02:15 PM
TheBlurLS1's Avatar
That's what she said...
HA!
You must not have heard too much about our cars. The crank pulley is not pinned, it uses an "interference fit" to keep it from spinning. This means that the pulley hole is just a tiny bit smaller than the crank. Sure the bolt will come out using an impact or a socket/breaker bar if you can keep the crank from spinning, but you're far from getting the pulley off. You have to use a 3-jaw pulley-puller to remove the crank pulley.
If you've got a 6-speed, you can throw it in 4th gear and remove the bolt as long as the clutch doesn't slip. With an automatic, you need to remove the starter and use a screwdriver to stop the flywheel from moving. There's a tool made especially for this sold somewhere though.
Old Jan 20, 2007 | 04:32 PM
longboard's Avatar
So the pulley will come off using a 3 jaw thingin. How hard is it to put back on? Dos it need to be aligned a certain way?
Yes, definitely a rookie. Trying to install an LS1 into a 61 Impala, but also trying to put a little polish on as I go.
Old Jan 20, 2007 | 04:34 PM
TheBlurLS1's Avatar
http://ls1howto.com/index.php?article=23
That outlines how to install the pulley. Pay attention to the different bolts needed, it's important.
Old Jan 20, 2007 | 05:56 PM
longboard's Avatar
Hey thanks Burl, that really helps!!
Old Jan 20, 2007 | 06:48 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Burl? Haha, you mean Casey? Burl = t3h blur =
Old Jan 21, 2007 | 07:33 PM
longboard's Avatar
Whoops, another rookie error. But good news!! That worked perfectly, but I could only get 195lbs (close enough) Thanks again!
Old Jan 22, 2007 | 01:32 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
195 is about as close as I get too.
