Ls6 Question Intake!
Old Jan 21, 2007 | 06:31 PM
NONOS's Avatar
Default Ls6 Question Intake!
I have a 1998 z28 ls1! I'am going to put on a ls6 intake! Will this intake bolt right on? What Do I need?
Old Jan 21, 2007 | 07:04 PM
BlackDuk98's Avatar
Default .
Yes it will bolt up, Here you go:
LS1HowTo intake swap and needed parts
Old Jan 21, 2007 | 08:13 PM
HeapaShifter's Avatar
Yep. It's a direct swap.
Old Jan 21, 2007 | 08:19 PM
c5formula's Avatar
You will need the coolant plugs.
Old Jan 21, 2007 | 08:26 PM
NONOS's Avatar
Can I get them at GM parts? (PLUGS)
Old Jan 21, 2007 | 08:33 PM
00BlackSS's Avatar
yes you can!
Old Jan 21, 2007 | 08:45 PM
NONOS's Avatar
Hey ,I would like to Thank all of you for the help!
Old Jan 21, 2007 | 10:36 PM
KurtRardin's Avatar
Veteran: Marine Corps
Be extremely mindful of the oil pressure sending unit thats inbetween the brake booster hose and the back of the intake. A LOT of people, snap it off. The hose WILL catch it if you arent carefull. Advance Auto and AutoZone dont stock it for a 98. GM does, and it will run about $40, plus an $8 socket that you can get at most auto parts stores. I had to order mine, which meant that i was off the road for a day just waiting on a part.
Old Jan 22, 2007 | 06:43 AM
TheBlurLS1's Avatar
That's what she said...
LS1howto.com
Try doing a little searching action. This topic has come up, literally, THOUSANDS of times.
