Problem after headers install HELP
Old Jan 23, 2007 | 08:23 AM
  #41
Specialized's Avatar
so its fixed? Coolant temp sensor? God my buddy at work suggested that to some guy and I laughed after we sold him the part. I guess a lot of people are careless and break them when doing work on the car?
Old Jan 23, 2007 | 08:25 AM
  #42
Camaroz's Avatar
Hey, I don't even remember hitting it I knew what it was and not to hit it... I guess I gave it a good tap with something
Old Jan 23, 2007 | 08:50 AM
  #43
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
well.. if it isn't a cracked plug... are you sure you snapped on the wires on the plugs and coils all the way?
Old Jan 23, 2007 | 09:09 AM
  #44
SIC LSX's Avatar
I have seen someone bend the inside of the coil pack plug! pull the plug out and see if any of the plugs are bent on the inside!
Old Jan 26, 2007 | 05:47 PM
  #45
Camaroz's Avatar
Alright bitches I got the codes!
P0118 Engine Coolant Temperature [ECT] Sensor Circuit High Voltage
P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
P0300 Random/Multiple Cylinder Misfire Detected
P0353 Ignition Coil C Primary/Secondary Circuit
P0357 Ignition Coil G Primary/Secondary Circuit
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0412 Secondary Air Injection Switching Valve A Circuit
P0418 Secondary Air Injection System Relay A Circuit
P0351 Ignition Coil A Primary/Secondary Circuit
P0355 Ignition Coil E Primary/Secondary Circuit
Alright so we can rule out AIR, EGR, Coil pack codes (I assume it's from unplugging my drivers coil's). So do you guys think a new coolant temp sensor will fix my problem?
Old Jan 26, 2007 | 05:57 PM
  #46
joecar's Avatar
Check your block grounds.
Old Jan 26, 2007 | 10:31 PM
  #47
Camaroz's Avatar
Which ones? where are they located?
Old Jan 27, 2007 | 04:15 PM
  #48
Camaroz's Avatar
ttmft
Old Jan 31, 2007 | 07:54 PM
  #49
Camaroz's Avatar
Alright ******** I got my coolant temp sensor and I have spark on my drivers side now but it's still missfiring like a bitch nflaskdjlgkskgf wtf! I don't know wtf is wrong? It has spark and it's still throwing a hissyfit.
Old Jan 31, 2007 | 07:58 PM
  #50
dpw41285's Avatar
mine was a tiny whole in a spark plug wire. there was still spark at the coil and plug. had to hook it up to a tech ii....and then let a drivability tech work on it.
Old Jan 31, 2007 | 08:17 PM
  #51
Camaroz's Avatar
Anyone think I could have gotten a bad O2 from Vatozone? Worth a try?
Old Feb 1, 2007 | 09:27 AM
  #52
joecar's Avatar
Sorry, I didn't get back here for a few days...
Grounds:
RHS of block near dipstick tube.
LHS of block near alternator.
LHS head rear (also holds bracket for AIR valve)
LHS + RHS fenders
LHS + RHS radiator support
I've experienced brand new parts being faulty.
Did you ohm your plug wires, and do they all look good...?
Old Feb 1, 2007 | 02:18 PM
  #53
greysteel_M6's Avatar
Bad wire. Sorry for the crappy redundant advice, but I'm stumped. Did you leave anything unplugged? It's got to be a problem with spark. Drop any of the coils during the install?
Old Feb 1, 2007 | 05:38 PM
  #54
Camaroz's Avatar
right now my car is throwing a few codes sorry I can't be specific but they are.
A couple bank 1 O2 codes, All the coil packs on the drivers side are throwing malfunction codes and a coolant temp sensor high circuit...
SO... I exchanged my new O2 sensor for my drivers side(it was covered in carbon and wreaked of fuel so I'm guessing it got fouled out). and I'm getting a new coolant temp sensor AGAIN tomorrow. I checked the grounds and they seem alright.
Old Feb 2, 2007 | 11:59 AM
  #55
Camaroz's Avatar
alright, I'm fed up with my car! I've replaced the coolant temp sensor twice and it's not throwing anymore codes now. I replaced my drivers O2 sensor and delete the code and it's not coming back. BUT! my car is still backfiring like crazy! I checked my drivers side coil with the oldschool method of spark plug + ground point and I have spark on my coils.
Old Feb 2, 2007 | 12:48 PM
  #56
blackops22's Avatar
Wow just read all of that. I feel your pain dude. Best of luck.
Old Feb 2, 2007 | 12:59 PM
  #57
TXCAMSS's Avatar
"All Motor 9 Second club member"
Are you sure the cam position sensor didn't get broke? You may want to try to disconnect the MAF and see if it idles any better. Something isn't adding up.
I wish you were close. I'd come dig around and see what we could find.
Old Feb 2, 2007 | 01:00 PM
  #58
TXCAMSS's Avatar
Exactly where in Tx is Chads mom's house?
Old Feb 2, 2007 | 01:06 PM
  #59
Freddyrdzls1's Avatar
i would also say to check the vacumm lines, a friend of mine his car was acting up as well for a stupid little vacumm line. plus a header leak? how about copper gaskets?
Old Feb 2, 2007 | 05:40 PM
  #60
Camaroz's Avatar
Hanover, Massachusetts I didn't check my CPS where is it exactly? I think I remember it's the drivers side of the motor?
