Putting my Fast 90 back together- Need a little help
While my heads are at AFR getting a little work done I decided to pull my intake apart to paint it and check out the porting job Mamo did on her. I have also noticed for the last couple hundred miles, I had some fuel build up around the edges of my intake where to top and bottom section meet. I am getting ready to reassemble my intake following a write up one of the members had done to reseal his intake. See link below
I have everything in order ready to go but I am having a problem finding a mold releasing agent to keep the silicone from sticking to the top half of the manifold when I lay down the silicone to seal this up
I was wondering if I could use Pam (the non-stick cooking spray) or another product that would work the same??
Any help or suggestions would be greatly appreciated.
Thanks,
J.R. Thomas
https://ls1tech.com/forums/showthrea...highlight=leak
Thanks,
J.R. Thomas
