who makes the best hedder gasket
Old Jan 23, 2007 | 08:57 PM
badnuz's Avatar
Default who makes the best hedder gasket
look 4 a good hedder gasket that wont blow out in a few weeks
Old Jan 23, 2007 | 09:00 PM
ssman00's Avatar
GM Factory Gasket
Old Jan 23, 2007 | 09:06 PM
Hell'sChariot's Avatar
Originally Posted by ssman00
GM Factory Gasket
They are the best!! Truth!
Old Jan 23, 2007 | 09:28 PM
s346k's Avatar
gm does
Old Jan 23, 2007 | 09:36 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Percy's Seal - 4 - Good or their Carbon XXX gaskets are excellent also.
Old Jan 23, 2007 | 09:41 PM
BriancWS6's Avatar
GM metal gaskets. You can even re-use them with no issues.
Old Jan 23, 2007 | 09:43 PM
Sublime4003's Avatar
Gm Ftw...
Old Jan 23, 2007 | 09:45 PM
Tainted's Avatar
perceys seal 4 good gaskets but GM's stock gaskets are good enough
Old Jan 23, 2007 | 09:48 PM
exstanger's Avatar
Never had an issue with reusing mine.
Old Jan 24, 2007 | 09:27 AM
lsx24's Avatar
Everyone is going to tell you GM, because they are proven.
Old Jan 24, 2007 | 11:17 AM
BlackBADaSS02's Avatar
GM Factory Gasket
The best
Old Jan 24, 2007 | 01:40 PM
TheBlurLS1's Avatar
That's what she said...
Percy's seal-4-good is the best.
GM's work awesome, don't get me wrong, but they are not the best. The people who are recommending them haven't had the Percy's gaskets. Either way you go, you'll probably be fine.
Old Jan 24, 2007 | 07:45 PM
LILWS6's Avatar
Gm for me too i used them on my install
Old Jan 24, 2007 | 08:12 PM
03 BUSA's Avatar
GM if you are only looking for a replacement. If you need something that is thinner due to compression issues I would say to go with Cometics, but only if you needed a different thickness than the factory.
Old Jan 24, 2007 | 10:11 PM
TheBlurLS1's Avatar
Header gaskets, not head gaskets.
This is assuming that hedder = header in Montana.
Old Jan 24, 2007 | 10:16 PM
miamifan3413's Avatar
GM Gaskets for sure!
Old Jan 25, 2007 | 04:21 AM
DONAIMIAN's Avatar
The GM gaskets arent bad, but once you have one go south on you then youll be all over the Percy gaskets.
Old Jan 25, 2007 | 06:37 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Old Jan 25, 2007 | 08:15 AM
TheBlurLS1's Avatar
Originally Posted by orangeapeel
This guy runs Hedmans......
Old Jan 25, 2007 | 12:15 PM
DONAIMIAN's Avatar
That pic cracks me up every time.
