Oil Catch Can **PICS**
Old Jan 29, 2007 | 09:15 PM
  #41
01pewterbird's Avatar
It's not that they fill up, it's not even possible for that container to become an 8th of the way filled. The vacuum pulls the oil out as is it circulates around the inside of the container, so it can only hold so much before it starts to get sucked out again. That's why after a couple days the amount of oil in them won't change because they can't hold anymore. Either way you look at it though you'll burn less oil since the oil in the container is oil not burned.
Old Jan 29, 2007 | 09:21 PM
  #42
PLucas's Avatar
I dont know how you would fill those up in 2 days. Mines similar to that and mine fills up about every 5,000 miles....
Old Jan 29, 2007 | 09:52 PM
  #43
Hell'sChariot's Avatar
What catch can do you have?
Old Jan 30, 2007 | 07:17 AM
  #44
I run an AMW which has rings within it for the oil to circulate in(this way it doesn't just swirl around the walls and reach the top to get sucked through), and Plucas if you read my post, they don't fill up, they can't.
Old Jan 30, 2007 | 08:10 AM
  #45
PLucas's Avatar
Mine does fill up....not to the very top, but it takes it a while for it to get even that high.
Old Jan 30, 2007 | 01:57 PM
  #46
I don't see how thats possible with such a small canister. I think some pcv's may also just pull more oil then others depending on the car.
Old Jan 30, 2007 | 02:04 PM
  #47
SpaZMaN's Avatar
Originally Posted by TORCHD 02 TA
Post a pic...
im in the process of using diffrent hose, therefore its all apart, give me a day or so to get new pics!
Old Jan 30, 2007 | 02:07 PM
  #48
SpaZMaN's Avatar
Originally Posted by orangeapeel
Works fine for me! I haven't even had any residue on the tail pipe yet! But also, when you are running High RPMS, that is when the catch can is working. Basically the same horse just different color.
would it be possible to use the stock EGR location to do this?
Old Jan 30, 2007 | 04:04 PM
  #49
TORCHD 02 TA's Avatar
i re-did mine. after work i will get the new pics. pretty much the same location, but ther is no kink in it...
I hope my PCV valve is ok.. i pulled that thing out, but i am pretty sure that i got that little metal clasp around so it is sitting tight again......
Old Jan 30, 2007 | 04:39 PM
  #50
twospeed's Avatar
Looks good I like it!
Old Jan 30, 2007 | 05:35 PM
  #51
5_02ls1's Avatar
Default picky friends as well
Originally Posted by myfast70
I'm not trying to be a dick, but I would be embarassed and made fun of by my friends if I opened my hood and they seen that. It looks like you robbed your air compressor of parts. I will give you an A for creativity though!
my friends would also give me hell.looks like it would work good but with the hood open at a local gathering id catch hell.im not throwing off on the setup in any way.but my friends are very nitpicky.
Old Jan 31, 2007 | 01:23 PM
  #52
sorry i did not post the pics was tired after the gym/work... i will post them tonight
Old Jan 31, 2007 | 01:59 PM
  #53
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
i got the dual huskey too and it's working so far
Old Jan 31, 2007 | 03:07 PM
  #54
Ripper415's Avatar
not true, this is a pic of mine after about 500 miles of driving.
http://memimage.cardomain.net/member...46_24_full.jpg
you can clearly see the can is about 1/3 full. this was the first time i emptyed it too. the 2nd time i let it go even longer and it was honestly almost halfway filled. and unless you drive 200 miles a day i dont see how you can say you need to empty it every 2 days. most people on here have these cars as weekend drivers, or dd's without hour long commutes each way. i'd say for the average person on here, emptying them once or twice a month will suffice.
Old Jan 31, 2007 | 04:04 PM
  #55
jsut in case it does fill up, that is why i have 2 of them in the line.. Added protection
Old Jan 31, 2007 | 07:19 PM
  #56
UPDATED PICS IN POST #1
i hope that my PCV is ok. i took it out to inspect it, i got it back in, and got that metal peice back around it. Just want to make sure it is ok. And i got the hose back around it to make sure that it seats properly...
NOW WHAT DO YOU ALL THINK???
Old Jan 31, 2007 | 08:29 PM
  #57
dpw41285's Avatar
nice so know more "killing air flow" lol
Old Jan 31, 2007 | 08:32 PM
  #58
Nope no more killing the air flow.. you approve then
Old Feb 1, 2007 | 07:17 AM
  #59
there you go buddy, no more kinks.
Old Feb 1, 2007 | 09:28 AM
  #60
SpaZMaN's Avatar
the kink was the only problem bro, that oil get the hose so hot it tends to cavitate of not done right.
