Magnaflow for td's?????
Old Jan 27, 2007 | 07:29 PM
sickws698's Avatar
Default Magnaflow for td's?????
I was looken on ls1sounds.com in the true dual section and i came across a magnaflow with the same set up i will be running and in the video it sounds amazing....( 26th down from the top,02 ss,kooks,ORX) < thats the videos that i saw, theres 3. If anyone has this set up or has herd it in person how does it sound? also is it pretty close to the sound in the video?
Thanks, josh
Old Jan 28, 2007 | 01:07 AM
Time2Kill's Avatar
MASS seller approved
Which Magnaflow mufflers were they? Most people use the 4" or 6" round mufflers, but I have also seen some people use the 4"x9" oval mufflers.
Old Jan 28, 2007 | 10:29 AM
sickws698's Avatar
im not sure, all it gave was a number under it....wich is better?
Old Jan 28, 2007 | 10:30 AM
sickws698's Avatar
bump./...
Old Jan 28, 2007 | 10:31 AM
99Hawk262's Avatar
Thanks, josh
I believe you are talking about Meents.....and if so, yes his car does sound amazing. Hopefully he'll post up and tell you what kind he used.
Old Jan 28, 2007 | 10:41 AM
flyinZ's Avatar
The 4x9 ovals are what your wantin'..Thats what I switching to after I get my trans. work done.
Old Jan 28, 2007 | 10:47 AM
sickws698's Avatar
meents?
also yah im not to sure on all the different sizes and what sounds they produce....
Old Jan 28, 2007 | 01:35 PM
sickws698's Avatar
bump...
i found the meents guy and just pmed him
Old Jan 28, 2007 | 02:52 PM
99Hawk262's Avatar
meents?
He's the member who owns the car you saw in the video. Just wait and he might reply.
Old Jan 28, 2007 | 04:39 PM
MeentSS02's Avatar
Kleeborp the Moderator™
For what it's worth, the video sound is pretty close to what it is like in real person, but in person, it is much louder (at least it is to me). The mufflers are the 4" round (2.5" inlet/outlet) bullet Magnaflows - the part number for them is what is listed on ls1sounds.com.
If you click on any of the stuff in my signature, and go to my picture gallery on FQuick.com, you'll see some more pics from underneath of the entire setup. The same videos on LS1Sounds are also in my sig...
Any other questions? Let me know...I'm hoping to get some more vids once it gets warmer out. Those videos are about a year and a half old. Not much has changed in that time, but I'd still like to update them.
Old Jan 28, 2007 | 05:17 PM
sickws698's Avatar
okay, thanks alot guys...as of now im thinking of just going with those mufflers he has....
what els would be a good choise muffler wise for the td's???
bump...
Old Jan 28, 2007 | 05:27 PM
MeentSS02's Avatar
I think if I did it again, I might go with a larger round muffler (like the 6" instead of the 4" round bullets). I would have done the Borla XR1s, but they only do a 3" in/out in the kind I wanted, and I needed 2.5" back there (although I guess I could have just put an expander on each side to make that happen, but it was kinda tight back there as it was). The main problem I had is with incorporating it into the CME tips that I wanted to keep...it gives you a little less length to work with since the tips need to exit in a certain spot. I could have gone with some larger mufflers had I not been constrained by that.
Old Jan 28, 2007 | 05:29 PM
MeentSS02's Avatar
https://ls1tech.com/forums/showthrea...ht=kooks+duals
I'd probably try to source some mufflers like the ones in the very back on that setup...I think once I get into engine mods, this system might be a bit too loud for me. Only time will tell though...
Old Jan 28, 2007 | 06:07 PM
flyinZ's Avatar
So, magnaflow makes them in a bullet style?
Old Jan 28, 2007 | 06:18 PM
Ashish's Avatar
magnaflow magnapacks are bullet style mufflers
Old Jan 28, 2007 | 06:27 PM
MeentSS02's Avatar
Just do a search on Summit Racing for "Magnaflow 10416." Those are the mufflers I'm using...Summit also carries a whole host of other shapes/sizes.
Old Jan 28, 2007 | 07:02 PM
sickws698's Avatar
a bigger one like the 6" what would that do for me sound wise?
Old Jan 29, 2007 | 09:08 AM
Time2Kill's Avatar
I can do a pair of the 10416 for $92 shipped
The 6" rounds should make the exhaust a bit quieter and a bit deeper.
Old Jan 29, 2007 | 09:15 AM
Time2Kill's Avatar
Another good choice is the Borla XR-1 round mufflers. They are a 5" bullet style. They have a much deeper sound than the Magnaflow round mufflers. Everyone I know that has heard both in person prefer the sound of the XR-1. We sell them for $110 each + shipping.
Another good choice would be oval mufflers from Borla or Magnaflow.
Old Jan 29, 2007 | 12:16 PM
andrew69_04's Avatar
I went with the dynomax pro flo 6" round 3"in/out mufflers. sound very nice but clearance is tight. quieter than bullets but still loud and a good deep tone. sorry no sound clips though
