02 Sensor Sim? Need 4 ORY?
Old Jan 28, 2007 | 05:07 PM
blackops22's Avatar
Default 02 Sensor Sim? Need 4 ORY?
Alright well im going to be installing longtubes (pacesetters) on my Camaro. Im going to be also putting on an ORY. Do you guys know if I need 02 Simulators? Will it throw trouble codes if I don't?
Also any comments about pacesetters?
(Car info in sig)
Old Jan 28, 2007 | 06:07 PM
98Camarod's Avatar
You either need o2 sims or to get the codes tuned out with hp tuners or efilive. I just have o2 sims in for now. Im still waiting on my tsp true duals 1 month and counting......
Old Jan 28, 2007 | 06:14 PM
LS69TA's Avatar
Pacesetters are probably the best bang for the buck as far as headers go.
Old Jan 31, 2007 | 01:04 AM
blackops22's Avatar
Also how many O2 simulators will I need to purchase? ..im thinking 2, I just wanna make sure im right.
Also I heard the gaskets are pretty bad that they send you when your order Pacesetter Longtubes off a certain site starting with an "E". Is this true? Should I invest in better gaskets?
Old Jan 31, 2007 | 01:08 AM
GR33N GoblinM6's Avatar
yes JUST 2!!! and they only go in the rear positions...and yes get some better gaskets
Old Jan 31, 2007 | 01:19 AM
TheBlurLS1's Avatar
That's what she said...
All pacesetters come with the same shitty gaskets. Go with your stockers, or a new set of GM's. You'll also need 2 24" O2 extensions for the front O2's to reach the bungs.
Old Jan 31, 2007 | 01:21 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would just get them tuned out. The simms are gonna be hard to find these days. The smog ***** are crackin' down.
Old Jan 31, 2007 | 05:52 AM
truglow's Avatar
I bought from this sponser and they still have the o2 sims as a kit.http://www.ls1speed.com/ The sims do work but if you remove your air pump you will still get a code untill a tune.
 Michael S. Palmer
Old Jan 31, 2007 | 10:53 AM
look at it this way... O2 sims are about 80$ for a set + shipping of about 6$.. so 86$.. if you call up Speedinc.com.. they have mail order tunes (which i have one and it netted me 18rwhp) at the same time they can also adjust several perameters in your PCM, such as tuning out the rear O2.. deleting EGR and AIR.. turning on your fans earlier, correct your speedo for your gearing.. not to mention they upload a base tune into your car.. the cost is $150.. so if i were you.. i would pay the extra 65$ and get everything done in 1 shot..
because later down the road, you're eventually going to tune them out any ways.. why waste money on sims..
