Ignition question
Old Jan 30, 2007 | 09:17 PM
MoesSS's Avatar
Default Ignition question
From time to time my car resets its computer, resets trip and learning curve. Could this be caused by a bad ignition switch? The switch hangs from time to time and the vats have been disabled due to not wanting to read the key. Also can I replace the switch with an older GM not vats ignition switch?
Thanks.
Andy
Old Jan 31, 2007 | 11:07 AM
jam01's Avatar
no, not unless you want to modify your column. its probally more of a hassle to change it then it is to fix it the right way.
Old Jan 31, 2007 | 03:45 PM
RFERG43's Avatar
The computer will not reset unless it loses power from the "battery feed"
pin which should always be "hot". Loose wire?
Old Jan 31, 2007 | 03:54 PM
MoesSS's Avatar
Does the battery feed go through the ignition switch? This is an intermittent problem. Only happens about once a month. It is beginning to be a pita.
