fast questions
Old Jan 30, 2007 | 11:42 PM
transam600hp's Avatar
i have a 99 trans am 393ci motor 238/242@.50 with 630 lift ported lq9 heads to keep my compression down to 10.5 when it was dyno the first time it was lean on the bottom end and rich on the top end i just got down with all the new stuff tonight
Old Jan 30, 2007 | 11:43 PM
waterbug1999's Avatar
And all you put down was 420? Never heard of a 393 CI before..
Old Jan 30, 2007 | 11:44 PM
my car drives good on the bottom end with great gas milage i have gotin 350 miles to a take of gas on a road trip i get 270 around town
Old Jan 30, 2007 | 11:45 PM
Hes talking about in the RPM range.
Old Jan 30, 2007 | 11:46 PM
i thought that was low to my tq was only 396 i was shocked about that they said i need ed a better intake and tune for it it make on nos 530 wrhp and 650tq
Old Jan 30, 2007 | 11:47 PM
eagle only made it for a while now they only do 347ci and 383ci for ls1s
What shot you runnin??
Old Jan 30, 2007 | 11:51 PM
right now i am running 125 but with my new fuel pump and when i get bigger injectors i can go to a 300 shot but i will not go that far what power should i be makeing i pull some bad *** cars that dynoed 550wp my buddies 04 cobra and whit his nos he only beat me by 4 cars i dont get it
 Michael S. Palmer
Old Jan 30, 2007 | 11:55 PM
1st you say you have a 393CI, then you said it put down 420. Now its 125 shot with 530/650TQ.. Just seems to me thats something is up and you might be full of it. You only have 16 post's and you write like your 10 years old. I think I am done with this thread.
Personally, if I have a 393CI and put down 420 I would not be spraying anyhting on it to begin with. Hell my H/C 347 CI puts down more then that..
Old Jan 30, 2007 | 11:59 PM
ill tell u that i am a grow man and i know what i built i have all the paper work to prove it look on my myspace and see for your self
http://www.myspace.com/bad99transam
Old Jan 31, 2007 | 12:00 AM
also my car has never really been dyno tuned ethir
Old Jan 31, 2007 | 12:01 AM
  #32
Sorry, at work and cant go there...
If your legit, I would start to work the bugs out N/A before spraying anything into the motor..
  #33
Thats a start...
Old Jan 31, 2007 | 12:10 AM
  #34
my hole motor has 393 short block with stage 3 lq9 heads with 2.8/1.60 valves a cam of 238/242 duration at .50 630 lift 1.8 rocker ratio. ported ls6 pump, fast 90/ 90tb slp lid slp lt headers borla cat back, bmr touqe arm lake wood lower control arms slp subframe connetors 01 camaro ss wheels with micky drag radials 36 pound injectors and a 255lph fuel pump with a eaon posi w 3/73 gears and a stud gurdle and nos a built t56 with stage 3 centerforce cluch and ram cluch master cyclander and a corvete slave cylander
Old Jan 31, 2007 | 12:21 AM
  #35
TheBlurLS1's Avatar
That's what she said...
Untuned stroker with aftermarket injectors and it won't run good, well, that's probably the problem. Click the alpha. sponsor lister at the top, enter your zipcode, and find one to take it to ASAP.
Old Jan 31, 2007 | 12:24 AM
  #36
ok thanks what do u think i should make
Old Jan 31, 2007 | 12:48 AM
  #37
TheBlurLS1's Avatar
Those inches, that cam, and decent heads should make 475+rwhp with tuning considering you've got LT's and a 90/90. There's really no way to tell, because every car is different though. A cam that size in that motor should make great torque though.
Old Jan 31, 2007 | 01:23 AM
  #38
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Looks like a magic stick. I would opt for a bigger cam. But that is just me
