View Poll Results: cutout open or closed
cutout open
57
89.06%
cutout closed
7
10.94%
Voters: 64. You may not vote on this poll
Cutout!!!
Old Feb 15, 2007 | 12:09 AM
staringback05's Avatar
^^^^my cap took the same route as your AIR pump fuses....
Old Feb 15, 2007 | 03:33 PM
LilSlo1's Avatar
Originally Posted by DMONEY06
I had my cutout open and was alot louder with a little bit of a loss in hp, when its closed it seems like it has more power why is this what kind of opinons do u guys have???
Thats odd, I got about a .25 of a second gain with the cut out open.. Do you have a cam in your car ? If you do and if the cam is too big then yes I can understand that happening.
Old Feb 15, 2007 | 04:21 PM
Ima get mines's Avatar
T-Rex cam, 4000 stall and flowmaster. My car sounds wicked/loud with the cut out open, It feels more powerful too. Maybe its because i feel like i'm driving a dragster!!
Old Feb 19, 2007 | 11:45 AM
mycamaroSS's Avatar
yea i see mto feel more hp with it open
Old Feb 19, 2007 | 11:31 PM
Go Topless's Avatar
Originally Posted by orangeapeel
They only come with a cap for inspection day.
I left mine open on inspection day just for a laugh, never seen so many heads turn in an inspection line before......and it passed!
Old Feb 20, 2007 | 12:18 AM
5_02ls1's Avatar
illn find out tommorow i just done my exhaust this weekend and havnt took the cap off yet.
Old Nov 5, 2007 | 01:31 PM
1FSTLS1's Avatar
What effect does cutouts right where the cats should be have on the 02s? Mine seemed to have less power with them open. Where are you guys mounting yours. Could it just be that it is soooo loud that it should seem faster?
Old Nov 29, 2007 | 04:07 PM
1320 killer's Avatar
open that bitch up and raise hell.
Old Nov 29, 2007 | 06:07 PM
g-ryde1's Avatar
+1 wide open
unleash camaro
Old Dec 1, 2007 | 10:35 AM
Ragtop 99's Avatar
If you loose HP or torque with an open cutout there are only possible reasons:
1) You need to fix your tune. (90+% of the issues)
2) your cut-out placement/installation is FUBAR. A cut-out should not reduce exhaust gas velocity when properly installed unless install it so far upstream that it messes up your header collectors. Some dual cut-out Y-pipes can effect torque by being too close to the collector.
Old Dec 1, 2007 | 01:01 PM
when I had mine I liked it open for sound and power.
Old Dec 1, 2007 | 06:30 PM
  #32
Jeremiah's Avatar
My 570 Rwhp SS gained 1 rwhp and lost 4 rwtq with the 3" cut out wide open Vs. the closed cut out and Hooker cat back.
I was making enough exhaust pressure on the dyno during tuning that I was plugging the air/fuel probe with muffler packing material on every pull. That was with the SLP dual/dual set up. I ended up buying the Hooker just so we could finish tuning and was very pleased.
A lot of you in this thread have zero real world numbers/results to post, only guestimates. A lot of you also claim that all cars will make more power with a cut out, I guess bigger is allway better?
Old Dec 1, 2007 | 07:37 PM
  #33
SmaknaSS's Avatar
Bigger was better in my case by 6 RWHP.
