heat soke . . . .
Old Feb 6, 2007 | 07:34 PM
King Nothing's Avatar
Default heat soke . . . .
i'm puttin the lingenfelter intake on my 00 SS and i know about the whole heat soke **** people keep bringin up to me . . . isn't heat soak more of a problem for those who 1/4 all the time as oppossed to those who just DD the car?
Old Feb 6, 2007 | 07:41 PM
Tainted's Avatar
its a factor no matter what but unless youre really wanting to do a lot with the car I wouldnt worry about it
Old Feb 6, 2007 | 08:04 PM
ok thanks
Old Feb 6, 2007 | 08:15 PM
dpw41285's Avatar
dont worry about it..search the metal intake thread. i will be installing a 85mm on it and having it ported to my heads. SO GAINS out weigh the bad. especially if i have a nitrous backfire
Old Feb 6, 2007 | 10:52 PM
but for now i won't be porting at all or running nitrous
Old Feb 6, 2007 | 11:13 PM
dpw41285's Avatar
did you search the metal intake thread...its been tested heat soak is a non issue
Old Feb 8, 2007 | 08:58 AM
lsx24's Avatar
I like the analogy of a car heater, or a hair dryer, simply running air past hot filiments heats up the air. So obviously your air intake is going to be warmer with an aluminum manifold.
Would I worry about it for a street car? No. It's probably not costing more than a few hp, and unless you drag race and need to see every little last bit of hp, I wouldn't even worry about it.
Old Feb 8, 2007 | 11:21 PM
good answer! thank you!
 Michael S. Palmer
