Coolant crossover pipe
Old Feb 10, 2007 | 10:50 AM
85ta383's Avatar
just kinda thinkin here.
could you cut the ends off of an ls1 style coolant line (the front 2 ends, just use the back as it is.)
flair the end of line out to accept 3/8 in hose or similar fuel grade hose.. slip the hose over the flaired end, put a plastic T in there to hook the lines to the coolant and and use that?
seems to me it would be no different than what we are doing here.
I dont know that i would want this in the back of the intake since its so cramped and you couldnt look for leaks easily but i do think this would work on the front pretty easily. Ill probably try it in the next few weeks and let you know some results.
