Vacuum diagram for LS1...
Justin.
Also, there's a vacuum canister up behind/below the passenger side headlight somewhere, it may be a problem too.
However, I don't have that panel on my car anymore (for some reason it broke). Looking at those lines, there are different colored vacuum hoses? Hmm, I'm going to have to check it out and then get back to ya. Thanks for the help.
Do you have a breakdown of the number system? I didn't know if that was included in the book. If not, well, that's okay, I can toy around w/ this all day.
Justin.
And I explained it backwards earlier. Vacuum line #17 comes through the firewall and connects to #18 which connects to the interior control ***** and then spreads out to all the relays and switchs for the ac/heater controls.
And to answer your question, yes the AC controls will operate the diverter if I have the "T" in the place it's been for the last year and a half.
Other option is to use a vacumn pump on the system and listen for the leak or??? that way the engine doesn't have to be running.
Good luck
