I am doing my own TD Setup and.........
Old Feb 12, 2007 | 01:16 PM
josepy121380's Avatar
Default I am doing my own TD Setup and.........
Has anyone else done this? I do not have a pipe bender to use. So I am going to order all the stainless from summit or jegs. If so how many different bends did you use? I am looking to do 2.5 inch system with x-pipe with 1 chamber flows over the axle. Not expecting many answers.
Old Feb 12, 2007 | 02:11 PM
to-fst-4u's Avatar
i made my own true duals, but i made all the bends myself without a pipe bender. If you are going all stainless, its gonna be alot of tig welding. if there is anything i can help you with let me know.
Old Feb 12, 2007 | 02:12 PM
V6 Bird's Avatar
Id order about 5 of each style of bend.
5 45's.
5 90's
5 180's
Old Feb 12, 2007 | 02:24 PM
How did you make the bends. Were the pipes crimped. You have any pics?
Old Feb 12, 2007 | 02:34 PM
to-fst-4u's Avatar
I already had one bend, used part of my old y pipe and on the other bends i had to cut and weld cut and weld to make my bends. i think it came out well....
Old Feb 12, 2007 | 02:42 PM
looks good to me and that was ran out the back?
Old Feb 12, 2007 | 02:46 PM
to-fst-4u's Avatar
no its dumps before the axle, but i have it left to where i could make it run out the back
Old Feb 12, 2007 | 02:54 PM
you use stainless?
Old Feb 12, 2007 | 04:44 PM
to-fst-4u's Avatar
you use stainless?
no it is aluminized exhaust piping. i dont have a tig welder to weld stainless.
Old Feb 12, 2007 | 05:28 PM
how is it holding up? did painting it help keep it from rusting out?
Old Feb 12, 2007 | 06:28 PM
to-fst-4u's Avatar
its holding up fine. being that it is aluminized piping, it should not rust anyways. the only reason i painted it is to make it less noticable under the car...it was silver before.
Old Feb 12, 2007 | 06:31 PM
i like think i will paint mine also.
Old Mar 22, 2007 | 12:38 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I guess you mig'd the setup together? Looks great man. I kinda did the same thing out of another x pipe section.
Old Mar 22, 2007 | 01:20 PM
GT Griller's Avatar
U have any pics of them on ur car?
Old Mar 23, 2007 | 02:41 PM
lsx24's Avatar
Doing your own is a bitch. It's tough to tell what you are going to need. If you can return them, do what recommended above and buy like 5 of each, and a bunch of straight piping. That will be your best bet.
Old Mar 23, 2007 | 03:00 PM
A-Dub's Avatar
You can't buy stainless Flowmaster's either, so you are paying extra money for stainless pipe welded to an aluminized muffler....
Old Mar 23, 2007 | 09:10 PM
Ping King's Avatar
you should be able to get away with 4 45's or 4 90's.
Ive noticed that a chop saw from home depot helps oodles. Allows you to make angle cuts and slight bends in the pipe.
Old Mar 23, 2007 | 10:49 PM
justin quick's Avatar
Keep up your thread as you start doing your exhaust. When i get more money saved i am going to be making my own TD system so it would help to be able to keep up with your build. I am going to run stainless 2.5 inch piping with the cats off my existing set up into an x pipe then i think im goin with one of the mufflers/resonators from Stainless Works, Under the axle and use the tips fom my existing set up. I have spent a lot of time doing research and measuring, mock up crap for the past while so i will be very interested in seeing how your build goes. good luck.
