What starter?
Old Feb 13, 2007 | 07:52 PM
ewingr's Avatar
Default What starter?
Doesn't seem like this should be complicated, but I'm not sure on it.
I have a 2004 Corvette LS1 Engine. It has a 4L60e transmission boltled to it. The flex plate I purchased from someone here on the forum, and I think it's a Camaro plate. It is not the flat one. It is dished.
So, what starter do I order for it? I thought 99-2002 Camaro possibly. But then, I looked on an online parts catalog, and a 99 Camaro Z28 has a different starter listed from a 2002 Camaro.
Any suggestions?
Old Feb 21, 2007 | 05:48 AM
WILWAXU's Avatar
Same starter. In fact most the LS series motors that I've seem use the is the same starter (trucks included)
Old Feb 21, 2007 | 07:02 AM
ewingr's Avatar
You say 'same starter'. You are saying 'same for all'?
As I noted in my post, they are different from a '99 to a '2002, so that is whay I asked the question. Now, I say they are different based on looking online at a parts store, and they came back with different part numbers for each year.
Old Feb 26, 2007 | 10:06 PM
WILWAXU's Avatar
You can use the newer and older starters. The difference is in the starter housing. Newer stuff has 2 long bolts where the older stuff has one long and one short. With the right bolts, they're interchangeable between the years.
Old Feb 27, 2007 | 08:20 AM
ewingr's Avatar
Thanks so much for that detailed explanation. That helps.
