O2 Sensor Install - What do I do with them?
Old Feb 17, 2007 | 12:08 PM
blackops22's Avatar
Default O2 Sensor Install - What do I do with them?
Im kind of confused on what to do with these O2 sensors for my LT header install. My guide just says go ahead and connect them..!?? Ive got two O2 simulators.. and there are four right.
So what do I with the two front ones and two back ones?
Old Feb 17, 2007 | 12:14 PM
NviouSS's Avatar
the front sensors are a must. you can either use o2 sims for the rear or have them tuned out.
Old Feb 17, 2007 | 12:16 PM
blackops22's Avatar
Alright so I just unclip the rear ones and put on the sims? Then I guess tuck them up somewhere.
And for the front ones do I just screw them back into the hole at the bottom of the headers (After extending them)?
Old Feb 17, 2007 | 12:23 PM
NviouSS's Avatar
yup. i would screw the front sensors in first then plug them in.
Old Feb 17, 2007 | 03:02 PM
staringback05's Avatar
becareful with them, there pretty fragile underneath that metal sheet
Old Feb 17, 2007 | 08:49 PM
trans2000am's Avatar
you but the front o2 sensors and buy sims for the back make sure you tuck them good they burn easy next to longtubes, trust me.
Old Feb 17, 2007 | 09:16 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you can't find sims, I would opt for having them just turned off with HPTuners or EFI Live.
Old Feb 18, 2007 | 05:40 AM
this ^^^^ would be a better idea anyways....considering sims have a tendancy to go bad, thus you have to buy more, when you could just turn them and never worry about them again
Old Feb 18, 2007 | 12:44 PM
torlak_t's Avatar
is the corvette sensors longer than camaros? and can we use them with pacesetter LTs cos i need to replace my sensors and do not want to buy extension if corvette sensors are long enough for headers?
Old Feb 18, 2007 | 01:07 PM
NviouSS's Avatar
yes to both. bosch 13111. they're pretty pricey though.
Old Feb 18, 2007 | 01:20 PM
TheSilverOne's Avatar
i heard the search button works as well as the sticky above titles EGR - AIR - O2 Sensors - Motor/Tranny mount FAQ!
Old Feb 18, 2007 | 01:59 PM
torlak_t's Avatar
aaa thanks for the input!!!
