anyone got eletric cutout switch pics?
How difficult is it to "undo" the standard QTP wiring so that the cutout can be operated with a convertible switch?
Thanks,
Josh
So basically, find the two wires that come from the cut out (mini-jack) wiring, and just start with those. The rest of the wiring you figure out from the diagrams for hooking up the vert switch.
Justin
Whoever suggested using the cig. lighter might want to reconsider. You need a switched 12v source. I believe the cig. lighter is a full-time 12v source. The little light on the end will always be lit and could drain your battery down over an extended period of time.
