anyone got eletric cutout switch pics?
Old Feb 20, 2007 | 11:25 PM
408Maro's Avatar
Default anyone got eletric cutout switch pics?
anybody with them got pics of there switches and how do you like them? Also was it hard to wire up? thanks guys
Old Feb 21, 2007 | 12:30 AM
iceman15's Avatar
i ran my switch to the ashtray, no one ever knows its there unless i open the tray lid. I just ran the wiring through the shift boot and center console.
Old Feb 21, 2007 | 12:42 AM
TheBlurLS1's Avatar
That's what she said...
Mine is next to the seat, by the seat adjuster buttons. It pulls power off of the seat power supply, which is a good location. At this location, you can disconnect the wires with a connector, and wire the cutout in on the dead side. Using this method, you won't even have to disconnect the battery.
That circuit uses pretty heavy wire and is fuse protected to handle quite a bit (electric motor for the seats). Just don't run the seat at the same time as you're moving the cutout.
If you watch the video of mine, you'll see the button mounted at the end, and it shows me closing it. I installed an e-cutout on a friends Borla and put the switch in the same spot as mine.
https://ls1tech.com/forums/member.php?userid=83762
Video is on the bottom right.
Old Feb 21, 2007 | 01:23 AM
00Formula00's Avatar
Cutout...
Switch is located right near the truk button....
Old Feb 21, 2007 | 08:14 AM
408Maro's Avatar
not bad thanks guys i appreciate it
Old Feb 21, 2007 | 08:56 AM
MISERICORDIA's Avatar
I'm rather proud of this mini switch I found at radio shack. I have it wired to some heavy gauge wire running to the back to power the amps. It has it's own fuse hidden under the console. Fits in that small spot in the ashtray so there is room for other switches if needed.
Old Feb 21, 2007 | 12:21 PM
ghettocruiser's Avatar
Cant get much more stealth than this... Except this is an 87 Trans AM...and not a convertable. Haha. So much other stuff going on in the car no one ever notices that it says "TOP".
Sorry for the blurry pic...
Justin
Edit: Oh...and info on how to wire it up...
https://ls1tech.com/forums/showthrea...=cutout+switch
Old Feb 22, 2007 | 09:34 AM
408Maro's Avatar
i like how that came out with the top switch looks nice cant tell
Old Feb 22, 2007 | 09:35 AM
408Maro's Avatar
on the qtp instruction it says i can tap into the pink tc wire my car dont have tc but the wires are there can i still use it?
Old Feb 22, 2007 | 09:56 AM
Check the wire to make sure it has 12v... Not sure if the fuse block is set up for TCS if your car doesnt have it. But it may be. If not, just tap into the cig lighter wire. That should work too. The idea is just to find a power wire that is close and convenient to tap into. If you have a test light or a multimeter just check whatever wire you want to use, and make sure it has 12v. If you want it to work with out the key in, make sure it has 12v without the key in... if you want it to only work with the car on... well you get the idea.
Justin
Old Feb 22, 2007 | 09:59 AM
408Maro's Avatar
makes sense thanks justin i appreciate it
Old Feb 22, 2007 | 10:45 AM
itsok_ok's Avatar
how do you guys run it through the center console into the ashtray? do you have to take it all out? where are all the bolts, or does it just snap off somehow? dont wanna break anything you know. sorry to jump on your thread man, but im sure you want to know as well.
Old Feb 22, 2007 | 10:53 AM
408Maro's Avatar
no problem man i aint trippin off it. from what i understand its easier to run through from the under the car to inside with a stick shift.i nkow on the camaros if you open the center counsle you pull out the coin holder and take of the bolts under that and i belive theres a few more bolts around the front i cant remeber. hope that helps a lil bro
Old Feb 22, 2007 | 12:10 PM
To get the top plate (shifter plate) off, you open the console lid. Take out the coin holder. Take out the two screws. Then just gently start lifting up on the plate. There are a few little tabs that snap in along the sides. That should do it. Also dont forget you'll have wires behind the lighter socket so unplug those before you give it a yank. But thats it... only two little screws hold it in along with the tabs.
J.
Old Feb 22, 2007 | 12:20 PM
Sluggish's Avatar
I'm going to put mine in the ash tray...along with a line lock switch.....it will be a tight fit but clean
Old Feb 22, 2007 | 07:09 PM
shouldaboughttheZ's Avatar
going to install mine in the ashtray also. Hopefully this weekend.
Old Feb 28, 2007 | 10:09 PM
408Maro's Avatar
does anyone else with qtp cutouts lights stay on in the switch?
Old Feb 28, 2007 | 10:26 PM
clean99's Avatar
my buddies 96 ta has the convertable switch for his cutout looks pretty tight and very stock.
Old Mar 1, 2007 | 11:13 AM
itsok_ok's Avatar
cool, i think i will try to run mine through the center console and into the little compartment next to the lighter (since my car didnt come with the traction control) it will be
Old Mar 7, 2007 | 08:55 PM
408Maro's Avatar
mine dont have tcs either but i still got power thru there
