going FAST w/ cam only
Originally Posted by 300bhp/ton
Personally I've never seen such results and everytime someone says you'll loose low end torque I've asked if they can provide some proof. After 10-12 times of asking and no one providing anything I don't even bother anymore.
IIRC the LS6 intake was the best below 3500 and the FAST pulled away around 4500+ with bigger gains by 6000 rpm. The loss of torque given up by the FAST wasn't great; maybe a couple percent. Certainly wouldn't be an issue for someone looking for solid top end power.
I'm skipping the FAST this time around as the gains aren't big in the midrange and the bucks are big. I don't spend enough time above 5000 rpm to justify in this car since it is not set up for a drag car.
I also doubt very much you'll loose any low end grunt. It's one of these things people on the net spew about (but only by people who don't have a FAST 90).
...90/90 combo is the best proven as everyone knows this... you have to give a little to gain a little... although it's not like this for everyone
