Would there be a point to switching?
Old Feb 22, 2007 | 02:13 PM
VenomInside's Avatar
Default Would there be a point to switching?
I was thinking of switching from my ls6 intake to a Fast and aftermarket tb. Would there be any point?
Mods below:
Performance:
Hooker Full Exhaust
QTP E-Cutout
Comp "Custom" cam (231 237 .589 .595 112LSA)
Vigilante 3600 Stall
B&M Trans Cooler
Ls1 Underdrive pulley/Harmonic Balancer
Ls6 Intake
SLP LID
Mac Filter
Suspension:
Eibach Lowering Springs
Bilstein Struts/shocks/mounts
Trac-Tek Tubular *Weld in* Subframes
Appearance:
Window Tint (20% rear, 35% front)
Chrome 17x9 Z06's wheels
VFN Ws6 Hood
Autometer Trans Temp Gauge
XenonDepot 10000K HID'S
Other
Nitto D/R's 275/40/17
SLP Line-lock
Power Slot Rotors
HAWK pads
BMR Driveshaft Loop
Tuned @ Speed Inc.
Car made around 383rwhp/370tq
Old Feb 22, 2007 | 02:43 PM
RA4926's Avatar
fast 90/90 would make a difference, more air in more air out = more power
Old Feb 22, 2007 | 02:53 PM
TheBlurLS1's Avatar
That's what she said...
Wouldn't make enough of a difference to be worth it at the point you're at.
You can take that $1200 or so and put it towards a set of heads. Heads/cam/LS6 intake will make tons more power than cam/90/90. You could also buy a pretty decent nitrous setup for $1200.
Old Feb 22, 2007 | 03:24 PM
PowerShift408's Avatar
I agree w/ the blur. $1200 could make you a lot more power at your power levels. I only think the FAST intake should be used on stroker motors and radical stock cube motors.
Old Feb 22, 2007 | 05:03 PM
Red99TA's Avatar
I agree that $1200 will get you more power w/ heads or a nitrous kit but not everyone has the ability or wants to do heads. In my case I've had an LS6 for a couple years and decided to upgrade w/ my cam-only setup. I bought a used fast 90 for $600 and a NW 90mm TB for another $400. I then sold my LS6 for $300 so basically I upgraded for $700...much more reasonable than $1200 flat out if you ask me. Now I will probably end up doing heads later anyways but for a relatively quick mod that maximizes airflow I got what I wanted out of it (dyno in sig). Now if it's a mild cam I wouldn't recommend it as the gains won't be as much.
Old Feb 22, 2007 | 05:13 PM
Sounds just like i want to do. I wouldn't consider my cam to be a mild cam.
Old Feb 22, 2007 | 05:15 PM
landstuhltaylor's Avatar
depends on who you ask
Old Feb 22, 2007 | 08:32 PM
WS6nJAX's Avatar
Restricted User
i have to agree with the h/c guys. i would rather have a decent set of heads to go with a cam befoire i sent the $$$ on a fast combo. if you cant flow the added air, whats the point.
Old Feb 22, 2007 | 08:43 PM
Hwystar's Avatar
I talked to the people at TSP about the Fast 90/90 setup and they said with my setup I could expect a 10 hp increase, that's just not worth the price. I'll stick with my LS6.
Old Feb 23, 2007 | 02:29 PM
Red99TA's Avatar
That doesn't make any sense. You will gain that even if you were cam only with the 233/239. Hell, I gained more than that with stock heads. I don't know why TSP would tell you that. You've got a nice set of heads and a relatively big cam so you would see major gains w/ a 90/90 over the LS6 IMO.
Old Feb 23, 2007 | 09:32 PM
Hwystar's Avatar
[QUOTE=Red99TA]That doesn't make any sense. You will gain that even if you were cam only with the 233/239. Hell, I gained more than that with stock heads. I don't know why TSP would tell you that. You've got a nice set of heads and a relatively big cam so you would see major gains w/ a 90/90 over the LS6 IMO.[/QUOTE
I thought that there should have been a better gain than 10 hp, but there isn't a whole lot of dyno comparisons to go by. And there is to many variables with too many combinations, so for now I think I'll keep my money in my pocket until more side by side comparisons show up.
Old Feb 23, 2007 | 09:55 PM
99blancoSS's Avatar
Dont be a chump! 231/237 is not a small cam to anyone except a chump
And blur gave the best advice
