Help on LS6 intake install
Old Feb 25, 2007 | 06:16 PM
robs98z's Avatar
Default Help on LS6 intake install
Hi, i am getting an ls6 intake soon and was wondering what else do i need to do the install. Also, could someone recomend a website that sells what i need. I am installing on a 1998 Z28.
Thanks a lot
Old Feb 25, 2007 | 06:29 PM
senicalj4579's Avatar
try doing a search. theres more than enough info about the ls-6 intake in older threads. tons of info
Old Feb 25, 2007 | 08:12 PM
Blacker's Avatar
http://www.ls1howto.com/index.php?article=5
Old Feb 25, 2007 | 08:50 PM
WS6Chef's Avatar
Depending on what you are looking to do with your throttlebody should influence your decision on what kind of intake to use. If you go with a F.A.S.T. then you have to use their throttlebodies (they offer TB's from 80mm-90mm). I went with SLP because i wanted my engine to appear as stock as possible. I you decide to go with SLP and get a MAF sensor take the screen off to get a full 1000 CFM airflow vs 845. Since you are going through the pains of swapping intakes.....why not toss in a set of 1.7 or 1.8 ratio rocker arms too? just a thought
Old Feb 25, 2007 | 11:20 PM
5_02ls1's Avatar
you can get the ls6 cooliant line and plugs from a gm dealr.heres what i done.remove the coolant lines using a pipe cutter and a double flaring tool cut the lines at each corner leaving enough for the flare get some hi temp/press 1/4" hose and make new ones.i wish i wouldve got pics before putting the intake on it looks as if it came from gm this way.you will save about 50 bucks by doing this
Old Feb 26, 2007 | 12:11 AM
snake charmer's Avatar
yeah i made my own coolant block offs from my original pipe and never had any problems . if you do have problems with it leaking it would be hard to notice on the back end since some or most would evaporate before hitting the ground .
Old Feb 26, 2007 | 12:28 AM
TheBlurLS1's Avatar
That's what she said...
I did the same for a friend. Cut them off, crimped the cuts, then welded the seams.
http://i38.photobucket.com/albums/e1...f/IMG_1710.jpg
