Installed LS6 intake, got P0443
Old Mar 1, 2007 | 08:52 PM
oneBADDz's Avatar
Default Installed LS6 intake, got P0443
Got it immediately after the installation on the new intake, and thought it was the little line that runs to the rear of the intake from the wire loom on the passenger side because I broke it and repaired it, but I checked it out and believe it is fine. What would cause P0443?
Old Mar 1, 2007 | 11:02 PM
Z28_DAD's Avatar
Evaporative Emission System Purge Control Valve Circuit
Old Mar 1, 2007 | 11:10 PM
TheBlurLS1's Avatar
That's what she said...
EVAP solenoid is right next to the #1-#3 injectors. Line runs from a hardline next to the fuel line, into the solenoid, into the manifold behind the throttle body on the driver side. Check and make sure it's hooked up.
Old Mar 2, 2007 | 08:19 AM
oneBADDz's Avatar
Awesome, I'll check that out. Thanks alot. So what's the one on the back of the intake that I though was the problem?
Old Mar 2, 2007 | 08:36 AM
TheBlurLS1's Avatar
That tiny one on the back of the intake provides power to move the diverter inside the HVAC. When you switch from vent, to floor, to defrost etc.
