*Check Engine Oil* light is on???
Old Mar 3, 2007 | 11:42 PM
02trns_am's Avatar
Default *Check Engine Oil* light is on???
Tonight my check engine oil light came on. I just had my oil changed less than 500 miles ago. I haven't looked into it at all but anybody have any idea why this would come on? Low of oil? or wat? thanks for the help.
Old Mar 4, 2007 | 12:04 AM
sixvi6-camaro's Avatar
low oil... Take the 2 minutes and pull the dip stick and check it and add a quart.
Old Mar 4, 2007 | 12:22 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
make sure your drain plug isnt cross threaded as well.
Old Mar 4, 2007 | 12:25 AM
slowpoke96z28's Avatar
and whether or not the system was reset after the oil change.
Old Mar 4, 2007 | 12:30 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Depends on if it said check or change. If you need to reset it: Turn the key to the on position, but don't start it. Push the accelerator to the floor 3 times...then start the car. It should reset.
Old Mar 4, 2007 | 12:35 PM
02trns_am's Avatar
the oil looked a hair low but It was still way up in the operating level. I reset the light as orangepeel said and it went off. I guess that will fix it untill it comes back on. Thanks.
Old Mar 4, 2007 | 12:45 PM
Brian2006's Avatar
The oil light comes on whether it has oil or not. It comes on every 5000 miles no matter what I believe. Just follow orange peel on how to reset it.
Old Mar 4, 2007 | 12:46 PM
Brian2006's Avatar
Are you sure that's how you reset it? That's how some other chevy cars are but with mine you have to hold the trip/odometer button for 8 seconds with the key in accessory???
Old Mar 4, 2007 | 12:54 PM
2001NBMZ28's Avatar
Either method will work, key should be in the RUN position.
Old Mar 4, 2007 | 01:05 PM
02trns_am's Avatar
I think that did reset it. It went off as soon as I did that...
Old Mar 4, 2007 | 01:16 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
you can do either, but with the gas pedal method you don't reset your trip meter if you use it for monitoring fuel consumption.
I have done it both ways. I promise, it works both ways.
Old Mar 4, 2007 | 11:49 PM
i just use a tech2. cant never get the dang gas pedal reset to work.. for anybody that cares, the algorithm the pcm uses is pretty complex, but it cant adjust for dust/contamination or sense new oil, so the system should be reset at every oil change, whether or not the light comes on.
Old Mar 5, 2007 | 01:08 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You have a tech 2? DAMN! $$$$$
Old Mar 5, 2007 | 01:59 AM
SStheBest's Avatar
yup that lil tool was $2100
Old Mar 5, 2007 | 06:33 AM
RedWS6 00's Avatar
Hold in the Trip button on your dash for 20 seconds (maybe less) while your ignition is on but car not running. I always use this method to reset the oil light after changing the oil, there are other methods but I find this simple and not tried others.
Old Mar 5, 2007 | 09:59 AM
bjamick's Avatar
I do the Pedal to the floor method
Old Mar 5, 2007 | 10:08 AM
SSpdDmon's Avatar
I think the manual says 12 seconds. You can download it at www.mygmlink.com if you don't have one.
Old Mar 5, 2007 | 11:29 AM
BlackHoleSunSS's Avatar
Mine comes on whenever I start the car, it will stay on for about a minute or so, then turn back off, rest it then?
Old Mar 5, 2007 | 11:49 AM
RedWS6 00's Avatar
You dont have to turn the car on, just turn the key for your dash light to come on, hold in the trip/oil reset button for 12 seconds and the liht should go out, then start the car and you wont see that light for about 3000+ miles depends on how you drive.
Old Mar 5, 2007 | 07:23 PM
thats just part of the bulb test sequence, unless its staying on for longer than a minute. i think that if you put the veicle on the regular odometer and not the trip odometer, if you press the reset trip button for the change oil light, it wont reset the trip odometer
