View Poll Results: Which Motor/Trans Mount Combo
Stock/Stock
4.55%
Poly/Stock
21.82%
Stock/Poly
0.91%
Poly/Poly
63.64%
Solid/Solid
9.09%
Voters: 110. You may not vote on this poll
Replacing Motor/Trans Mounts - Which Combo?
Old Mar 7, 2007 | 12:04 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Forgot to add...have fun with the install. Hardest install I've done yet...do yourself a favor and drop the headers.
Old Mar 7, 2007 | 12:56 PM
TheBlurLS1's Avatar
That's what she said...
You'll spend more time doing the mounts with the headers in, than you would by pulling out the whole exhaust system and reinstalling it.
Old Mar 7, 2007 | 04:18 PM
silverbandit0996's Avatar
my t/d's bang the floor and the tranny when ever i take off slowly from a stop. would a solid tranny mount help me or hurt me?
Old Mar 7, 2007 | 05:20 PM
TheBlurLS1's Avatar
You need motor mounts, not a trans mount. Poly mounts would keep the motor from twisting over so far, and a small amount of clearance between the pipe and floor will be all you need. Mine's about 1/4" away, and has NEVER hit.
Beating the hell out of your exhaust system is another way to fix it.
Old Mar 7, 2007 | 05:21 PM
SiL3NtXWS6's Avatar
i had solid. Then i got a BMR kmember and was forced to go poly since that's the only way you can do it with the kmember (without fabrication/motor plates/other stuff). I would go back to solid if i could, but there is not TOO much of a difference.
Old Mar 7, 2007 | 09:16 PM
but i would think solid motor mounts would be a bad choice seeing as i don't have SFC's. do you think it would be ok?
Old Mar 7, 2007 | 09:21 PM
TheBlurLS1's Avatar
It would be fine. Poly motor mounts would do you just fine as well.
The unibody flexing won't have anything to do with the motor mounts bolted to the K-member. I think you need to get some SFC's regardless, I could really feel a difference when mine went on.
Old Mar 7, 2007 | 09:37 PM
jimmypop13's Avatar
I ordered prothane motor mounts and for $10 more, I got a prothane tranny mount. What are your opinions on the tranny mounts, should I put it in or not?
 Michael S. Palmer
Old Mar 7, 2007 | 09:38 PM
TheBlurLS1's Avatar
Put it on, only takes 5 minutes, but don't throw your stocker away.
Some people can handle it, some people don't care, and some people can't stand it.
Old Mar 7, 2007 | 09:42 PM
I don't know if they would clear the T/D's.
Old Mar 7, 2007 | 09:54 PM
jimmypop13's Avatar
i would think any 2 point SFCs would work with every exhaust setup
Old Mar 7, 2007 | 09:58 PM
  #32
ArcticZ28's Avatar
They might if you vote in my thread about motor/trans mounts.
Old Mar 7, 2007 | 10:05 PM
  #33
i did. i guess it didn't work, my computer is a piece.
Old Mar 8, 2007 | 11:09 AM
  #34
SS4Luck's Avatar
i have the energy suspensions tranny mount ande love it, easy to go in stays tight never would put anything else in... i have no experiance with engine mounts tho
Old Mar 8, 2007 | 01:11 PM
  #35
Louie83's Avatar
I voted poly/poly because it's what I have.
It went from wheel hop to smooth as butter. Well, the launch is smooth as butter but I kinda shake in my seat. Chicks dig the vibrator seats!
Old Mar 8, 2007 | 01:15 PM
  #36
Coy's Avatar
Coy
I have solid motor mounts, and a 1LE trans mount. I had the prothane trans mount, and it was rediculous inside the car. I am going to use the 1LE till it breaks, then re-install the poly. With the solids, it's not too bad, but you can feel it.
I'm pretty sure most of mine is clutch chatter.
Old Mar 8, 2007 | 01:16 PM
  #37
schultzsj's Avatar
I had way too much vibration with a poly tranny mount so I switched back to stock on the tranny. Poly engine mounts are great - no noticeable vibration and much firmer engine mount (no longer banging the Y-pipe).
Poly motor mounts are so firm that I don't see any reason to use solid.
Steve
Old Mar 8, 2007 | 02:09 PM
  #38
Coy's Avatar
Coy
I'm trying to rattle my teeth out, that's why I went with solids over poly's.
Old Mar 8, 2007 | 02:39 PM
  #39
Zger's Avatar
I have poly motor mounts (what ever Thunder sells) and a stock trans mount. It's fine.
Old Mar 8, 2007 | 02:51 PM
  #40
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
I'm do'n the tranny and motor mounts this weekend. Both Polly!
