Check Engine light on and blinking
Just something else to look at.
Start with the easy things first, then go from there. And I suggest not going WOT until you find out what the problem is.
These guys have given you a lot of advice - I'd suggest taking it to get the code read, and go from there, otherwise you're just grabbing in the dark.
random missfire codes are caused by plugs/wires/coils so you need to check them.
are your plugs gapped properly??
are your wires laying on the exhaust manifold?
are your wires hooked all the way in??
chances are your coils are ok so i would start with the plugs and wires first..if they are ok than i would deal with the coils and/or possible injector than go from there.
