Check Engine light on and blinking
Old Mar 9, 2007 | 05:37 PM
  #41
motomike734's Avatar
ik when i put my tr6s in compared to my stock plugs that were in it they are shorter in lenth. Ik you guys keep telling me to check them but im just gathering more info for tomorouw, would wrong gap cause this?
Old Mar 9, 2007 | 05:41 PM
  #42
m_ghonim's Avatar
150 miles per tank is bad yeah but I get that on my car every now and then. Usually when I have it sitting for a week or two cuz I need to drive my toyota for gas milage! Otherwise I'm psyhced when I get 200 miles per tank and my car idles at 1100 rpm could that have something to do with that?
Old Mar 9, 2007 | 06:55 PM
  #43
i just went and got the o2s i had from my lt install and i think i installed one rear one and one front one in the front. The o2s i have say ac 97 on one and ac 98 on the other with both afs on them what does this mean?
Old Mar 10, 2007 | 06:00 AM
  #44
TNTramair's Avatar
your o2's shouldnt cause a random cylinder missfire. it may cause other things to happen such as running it very rich or vice versa which in turn can foul out a plug giving you a missfire.
Old Mar 10, 2007 | 11:38 AM
  #45
i checked for a intake leak sprayed carb cleaner nothing happen. All wires are tight and i turned lights off and no arcs off the plugs.The plugs were removoed during header install so they didnt get hit.
Old Mar 10, 2007 | 01:38 PM
  #46
TNTramair's Avatar
did you recheck the gaps???? your gonna drive yourself up a wall tryin to figure this thing out....than your gonna put your head through a wall when you finally find it and its something as small as a plug gap not correct. do the simple things first.
Old Mar 10, 2007 | 04:14 PM
  #47
i was going to but i said ill just wait till it cools, i installed my dry shot kit instead. I dont mind doing the plug put the rear 2 on the pass side is gonna suck.
Old Mar 11, 2007 | 02:36 PM
  #48
well i pulled 5 out of the 8 plugs lol today and the driver side i got all them out and i found one with a crack. Then i found another badly cracked due to my stupidity. I could get the rear three out on the pass side. Should i reset the computer to get the code out or what
 Michael S. Palmer
Old Mar 11, 2007 | 03:44 PM
  #49
oneBADDz's Avatar
It should go away on it's own with a multiple misfire code
