Y-pipe vibration?
Old Mar 8, 2007 | 12:40 PM
nofearracing28's Avatar
Default Y-pipe vibration?
I'm lookin at a 02 SS that has pacesetter LT's with their ORY. When you under acceleration, there is a little vibration and moan-like sound coming from under the drivers seat. I've heard y-pipes hit the bottom of the floor, but none that have sounded like this. Its kinda hard to explain, but I'm thinkin that its the y-pipe hitting? Anyone else have this problem?
Old Mar 8, 2007 | 01:57 PM
Regal1's Avatar
It sounds like the Y is probably hitting something. I had that problem with my Mufflex ORY hooked to QTP's. Mufflex makes a stopper that clamps around the pipe with a snubber that hits the floor before the Y. What I did was take an old exhaust hanger with a rubber joint and welded it to the Y, like the mufflex clamp only cheaper. Alot of people have had success with changing the motor mounts to poly to stop the Y from hitting. If you wanted to check and make sure that it is the Y actually hitting the floor, you could temporarily wedge something non-flammable in the to see if it stops the noise.
Old Mar 8, 2007 | 06:15 PM
anyone else?
Old Mar 8, 2007 | 06:17 PM
5_02ls1's Avatar
yeah mine is doin the same thing its aggervating as hell im gonna put on some solid motor mounts and hope it fixes the problem
Old Mar 8, 2007 | 06:47 PM
stangnightmare's Avatar
same here....i just got used to it after a while
Old Mar 8, 2007 | 07:12 PM
00slowredz's Avatar
mine does the same thing....especially when u first start to accelerate
Old Mar 8, 2007 | 09:16 PM
discostu's Avatar
i had a noise off the y pipe and it was one of the two bolts that mount it one of them was stripped and caused the y to rattle just replaced the bolt and noise went away
Old Mar 8, 2007 | 09:49 PM
00slowredz's Avatar
i woulda never thought of that discostu
Old Mar 8, 2007 | 09:52 PM
its not really a rattle sound....it almost sounds like when a wheelbearing is going out, but not that loud...and from right underneath the drivers seat. maybe im just overreacting maybe??
