SES light
Old Mar 8, 2007 | 07:14 PM
motomike734's Avatar
Default SES light
i plugged my car in tonihgt came up as misfire in mulitply cyenders, i think is what it says, i rember it not being one but sayin it was one but diffrent one each time or something? It was blinking,
Old Mar 8, 2007 | 07:54 PM
Red99TA's Avatar
are you stock? this is a common light after a cam swap.
Old Mar 8, 2007 | 07:56 PM
ya im stock i just add bbk intake tb lts ory and unplugged egr air and rear o2s without a tune. I hav the rear o2s in the front and i heard you cant switch
Old Mar 8, 2007 | 08:00 PM
Red99TA's Avatar
okay so you ditched the front O2's and you plugged the rears into where the fronts go? If so then that will cause a light too. You MUST have your front O2's plugged in and functional. If you just put the rear sensors in the spot of the fronts and plugged the clips for the fronts in then I would think it would work okay. Not sure if the rears are a different part than the fronts.
Old Mar 8, 2007 | 10:45 PM
TheBlurLS1's Avatar
That's what she said...
Check fuses, check and make sure the plugs/wires are good and the coil pack harness is connected well. Cracked plugs are common, you may have more than one. You didn't install the LT's with the plugs in place did you?
Old Mar 9, 2007 | 05:39 AM
im not sure i had a engine shop put them in im going sat to have him switch o2s then ill have him pull plugs and check them
