Professional Products
are the TB out yet?..........didnt see them on ws6store
hey casey did you finish relocating your packs
First I have heard of the coil pack relo - gonna have to go search
fuerzaws6
Now for some purty new valve covers....
http://i38.photobucket.com/albums/e1...f/IMG_2883.jpg
http://i38.photobucket.com/albums/e1...f/IMG_2871.jpg
http://i38.photobucket.com/albums/e1...f/IMG_2877.jpg
"The stock coil covers will not fit with our manifold and fuel rail setup. We are working right now on a set of custom coil covers designed to work with our setup. We will have the prototype finished in a few days and I will post some photos here to get your feedback"
Our system has a line leaving the pump, and it hits a Y block. One side goes to the motor, other side goes back to the tank at the regulator. It bleeds off pressure through this and sends the extra fuel right back to the tank. That's why they call it a "pseudo return style system".
It's a good idea because you have less gas going through the fuel filter, which could clog it up that much faster. It's a bad idea because if any sediment DOES get through the fuel filter, it will just clog the injectors or get squirted for combustion.
....you put one set under the fuse box?................where are the others
....you put one set under the fuse box?................where are the othershttp://i38.photobucket.com/albums/e1...f/IMG_2864.jpg
The wires aren't any longer than SBC/BBC wires, to my suprise. I was able to use the 4 shortest wires in the kit on one side alone. I had to cut 2' off of some of the other side's wires.
-Ken
