Tb Coolant Bypass Mod
Old Mar 10, 2007 | 08:41 PM
02silvaZ's Avatar
i did it, don't know if it helped much but i like the idea of the t/b being cooler, hot air ain't a good thing
Old Mar 11, 2007 | 10:35 AM
Blu2000ss's Avatar
I did mine yesterday with a coupler, but i don't like how it fits. it doesnt leak but i don't trust it. I'm gonna go with a full length line just for piece of mind and it will look alot better.
Old Mar 11, 2007 | 10:45 AM
dpw41285's Avatar
how long are we talking?
Old Mar 11, 2007 | 11:23 AM
Dex's Avatar
Dex
Why not measure it??? Pop the hood take a peak. To hard??
Old Mar 11, 2007 | 11:53 AM
BlackedOut LS1's Avatar
I used a 2 foot piece of 5/16 hose from AutoZone, and 2 screw down couplers. It was the perfect length very neat, but trying to tie the line to the radiator is a bitch make sure you tighten those couplers very well.
Old Mar 11, 2007 | 09:15 PM
silverbandit0996's Avatar
i did it to mine and it got pretty cold here this year and my car still ran fine. P.S. you will probably gain nothing from this except a less cluttered throttle body. and the feeling of doing something to your car.
Old Mar 12, 2007 | 12:04 AM
sk8co's Avatar
i did mine yesterday and i just bought a 5/16 brass fitting that connected the two hoses. afterwards i zip tied it down so it was out of the way from any moving parts. did it in about ... 15 min. also the coolant flows from the driver side to passenger side of the TB
Old Mar 12, 2007 | 09:13 AM
dpw41285's Avatar
WTF?
what if my car was in storage and i was wanting to just swing by the local auto parts store and pick up the line? I like to be prepared, but i am sorry dex...
Old Mar 12, 2007 | 09:17 AM
dpw41285's Avatar
any way i swung by the auto store yesterday and picked up 3ft no help to dexs smart ***! also picked up a breather and 3 ft of 3/8 hose to do the pcv delete
Old Mar 12, 2007 | 11:44 AM
fortmyerspolice's Avatar
WTF?
lol owned
Old May 18, 2007 | 02:08 AM
ls1owner4life's Avatar
sorry somewhat off topic however; will T tapping the hose going from radiator, through TB, and into the motor be a good place to get accurate readings for an Autometer water temp gauge? Also which way is the colant flowing?
(Picture taken by LS69TA)
Old May 18, 2007 | 02:40 AM
  #32
sk8co's Avatar
driver to passenger
Old May 18, 2007 | 03:48 AM
  #33
oops. Meaning that the coolant moving from driver to passenger side would be as hot as the bottom of the block optional temp sensor location?
Old May 18, 2007 | 01:02 PM
  #34
Tony Orlando's Avatar
I never understood this mod. I get what people are trying to accomplish, but seriously- how much can the air really get heated for the brief instant it's passing through the throttle body? Not to mention the fact that the underhood heat already gets the TB up to scalding temperatures, with or without coolant running through it, so what's the point?
If you stop and think about what coolant actually does, it seems like the reason for the coolant flow through the TB is to remove heat, not keep the plate from sticking. I mean, that's why it flows through the block, right? So why does everyoen assume that it wouldn't give the same benefit in a TB?
I know I'm going to get flamed for this, but I've scratched my head about this "mod" for years and never seen the benefit.
Old May 18, 2007 | 02:05 PM
  #35
JohnnyC's Avatar
I did a calculation on this a while back, and showed that the coolant does not significantly raise the temperature of the intake air as it moves through the TB:
https://ls1tech.com/forums/showthrea...ight=tb+bypass
Basically, the conclusion is that the TB bypass mod helps reduce only the overall ambient temperatures under the hood, which can sometimes provide small power gains. The reduction in overall temperatures under the hood helps to cool the rest of the engine components (intake, ect.), which can help reduce the overall air charge temperature slightly. The TB was originally heated to help prevent TB icing under extreme (and rare) atmospheric conditions. This can occur because of the venturi effect of the air flowing through the TB restriction, combined with the presence of water vapor and a very cold air charge temp.
Old May 18, 2007 | 02:35 PM
  #36
That's a very good explanation- thanks. I still don't see how changing the routing of 18 inches of coolant flow can reduce underhood temps, but to each their own.
Old May 18, 2007 | 03:27 PM
  #37
JohnnyC's Avatar
The coolant heats up the entire throttle body to 200 degrees or so, and the TB radiates the heat to everything else under the hood. Once again, the effect is small but not completely insignificant.
Old May 18, 2007 | 04:21 PM
  #38
my tb doesn't get hot anymore plain and simple, only when its idling it does
Old May 18, 2007 | 05:39 PM
  #39
cals400ex's Avatar
i thought the fitting on the radiator was 5/16's and the one on the engine was 1/4"? i bought a 1/4" hose and it sounds like i may have got the wrong size. I just want to use one size hose to eliminate the adaptors...
Old May 21, 2007 | 07:16 AM
  #40
squirts1's Avatar
ok... here's my question. why do you even need to "bypass" it? from what i was just looking at on my car, there's an elbow coming off the engine from a small hardline that has a T on it. that elbow goes through the throttle body and returns to the radiator. why wouldn't you just put a cap on that hardline T and a cap on the radiator return and just remove that hose alltogether? it doesn't do anything besides return coolant from the engine in a small tube that goes through the throttle body. the only reason i can see that hose returns to the radiator is because it goes through the TB...
