will my loudmouth connect to the QTP ypipe without modification?
Old 03-12-2007, 11:31 PM
jimmyboy8301's Avatar
Default will my loudmouth connect to the QTP ypipe without modification?
I have the loudmouth and am getting ready to order QTP headers with their catted ORY pipe. Will the ORY mount up to the loudmouth without any or major modification?
Old 03-13-2007, 12:11 AM
chadtx01's Avatar
Should mount up no problem as long as they are both the same diameter...
If the y pipe is catted though, its not an ORY. ORY means no cats.
Old 03-13-2007, 01:50 AM
NBM99SS's Avatar
Yes you will just have to take out that little short piece of extension that goes into your factory y pipe. With the QTP y pipe your muffler will just go wight into the 4inch-3inch reducer piece
Old 03-13-2007, 03:06 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
The problem is usually with getting the Y to fit the headers and clear the bottom of the floor pan. The worst you are gonna have it is just knowing how much to trim off the end of the y to make it fit correctly.
Old 03-13-2007, 09:18 AM
ok, thanks for the help guys i appreciate it.
