Tick tick tick....pissing me off
I be if you took a long screw driver and held it to your ear and touched it to a few of your injectors you would hear the noise, Mine makes a tick noise it's just those damn injectors, as long as they are squirting fuel, I just turn up the music and don't worry about it.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
My LS6 does it as well. Not too noticeable under the hood, but if you kneel down by one of the front wheels you can really hear it. I need to check my 02s, since I had my exhaust completely welded I know it's not that.
#33
Haha, the best is when you go through a drive through....You'll hear the tick echo off the walls and it makes it sound louder...it is super annoying....although, there is a good chance my driver's side header has an small exhaust leak...eh owell, still sounds good and hauls ***.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#34
Originally Posted by 2_wacko
I noticed this tick after doing the Header,ypipe,gmmg swap. Everything is tight but still have the tick.
#38
Ok I just checked all 8 plugs and wires. One plug on the drivers side was loose, and one wire on the passenger side was about to come off. After fixing these 2 things no more tick, tick, tick.
