My custom ported FAST 85/85 - *PICS!*
FAST gets a premium for the larger opening which anyone can swap to who owns a 78 mm version by purchasing a new "top" which includes and changes the front snout. Assuming no leaks with the opened 78 mm discussed, it is a cost effective way to narrow the gap between the two which is only about 5 HP anyway. My 78 mm ported FAST (with a ported 78 mm TB) was worth 20 RWHP in my original 346 combo.....the ported 90 set-up netted me about 25 RWHP.
Even unported the delta between them is pretty similar.....
Hope this clears up a few things.
Tony
*edit* Thanks for clearing up the confusion, Tony.
If you already have a good epoxied and ported 78 mm TB (like a Mark Shaner piece or something similar) score a 78 unit cheap and just consider having it ported. Even at the prices I charge to do a very neat and thorough job your return on investment is still better than buying a larger 85 mm TB and cutting up the snout which might close the gap in half between the 78 and the 90 netting you 2-3 HP. For an extra few hundred you would see an additional gain of 10 RWHP and a similar bump in TQ (my ported FAST 78 set-up went 20 RWHP and 15 RWTQ stronger than my former LS6/78 set-up as I previously mentioned).
For grins I just whipped up this spreadsheet....prices and performance may vary slightly but I think the general point I am making would still be intact.
Manifold.............Avg Retail $$...........Typical Gain.........Cost/HP
Stk FAST 78.............700........................8....... ............. $87
Stk FAST 90 (w/ TB)..1200......................13................. ...$92
FAST 78 w/ 85 mm.....900.......................11............... .....$82
Ported FAST 78.........1200......................18........... .........$67
Ported FAST 90/90.....1700......................23............... .....$74
The key is to understand that the snout doesn't represent the largest restriction in the FAST hence the smaller gains when messing with it. Reshaping and reconfiguring the ports are where the larger gains in airflow and power can be unlocked....
Tony
Tony
Tony
PM me for any specifics concerning your porting needs but you can pretty much figure my pricing from the math. I think I may have more R&D invested in tweaking these FAST intakes than the manufacturer themselves IMO. Your paying for my execution which is top notch, the R&D time I have invested to provide you with the results, and the consistancy/repeatability of those results proven time and time again with many independent sources....the best type of validation. The work I do is very extensive (and time consuming as it is all done by hand personally). Do a search and look for comments from the people I have helped....
That said lets move foward because I'm not wanting to hijack this thread....I think LS1Formulation's "resourcefullness" was very good and so lets keep things on track here. I did feel the info I provided was on topic (talking about value and how much power the $$$ buys) and worthy of consideration. As I said....I evaluate mods and their cost effectiveness every day of the week and what I tried to provide you with was a quick rundown and perhaps a slightly different angle or perspective.
And yes....the 90 mm FAST is certainly somewhat of a profit center for Comp but that type of situation is more commonplace than you think in the industry. The bottom line is you usually pay more for additional power and in that respect the cost is somewhat justified.
(Think about a CNC ported pair of BBC Pro Stock style heads such as a Dart Big Chief etc......the castings might have an additional $200 worth of aluminum but the cost can triple what a set of standard style BBC heads go for with similar hardware).
Regards,
Tony
-J
Everyone has or had an 8 second daily driver too.
This is a good thread.
thnx for the info guys..
