True duals or GMMG/Borla setup
you're really not going to get that much more power. thats a lot of money to spend for a few hp/tq (if that)
not true.
i've ridden in a couple different cars, 1 stock manifolds and GMMG, another LTs + GMMG....they are MUCH quieter then my TDs. you can have a normal conversation in both of them, and you have to almost yell to talk in my car
and as far as feeling a difference, i guess it depends on what mufflers/cat back your running....but still, like stated above; i would say 3-5hp gain on average (if any). i think it's all in your head
Also, the H-pipe has given my car a noticeable increase in power under the curve as compared to the old Y-pipe. As far as the power differences between the two set-ups...I dynoed a best of 341rwhp & 353rwtq with the cat-back (GMMG) and a best of 346rwhp & 362rwtq with the true duals. But again, even though I didn't gain much peak, it does feel much more responsive down low and under the curve with my car.As for Borla, yuck. Borla + LT headers/ORY =
hey man are u a auto or m6 cause our number are right with one another
If I did run true duals, I would want it over the axle and out the back. That is just a preference of mine...
Also, sounds like I will get a little better sound and a little more power over the catback? Please correct me if I am wrong though.
going from pacesetter LT's, catted y, and TSP rumbler catback/ pacesetter lt's, no cats, TSP duals out the back...... i gained 1hp and 4ft lbs.
it might have been a little different but i was sucking oil from the pcv, time for a catch can!
on the other hand.......... damn did it sound mean on the dyno! lol
But I'm guessing as the motor is opened up for a cam or heads/cam, that is where the true duals might really shine up top.
you speakin of BayAreaSS? his setup is similar to mine (mine goes over axle) and his is a lot quieter then mine is too....kinda strange i thought..
yeah, i felt a lot of mid range difference when i installed mine and when the car goes into 2ed at wot traction is now a problem. im also on an ls1 intake manifold, i figure when i get the ls6 the duals might help a little more since more air is going in and out.
