home ported FAST results
Old Mar 17, 2007 | 09:36 AM
ls1 jeff's Avatar
Default home ported FAST results
Over the winter I removed my LS6/shaner tb and installed my ported FAST90/Speed Inc ported LS2 tb, and svo 30# injectors. Got the car back from Speed Inc yesterday with some pretty good results IMO. Heres the dyno sheet that shows before and after.
Here are the threads that detail what I did to my FAST and the install process(on a C5).
http://forums.corvetteforum.com/show....php?t=1609199
http://forums.corvetteforum.com/show....php?t=1633125
Here's a pic of the finished product.
Old Mar 17, 2007 | 10:41 AM
redtail2426's Avatar
very cool,how did your runners line up with your patriot heads,did you do any port matching..And did you use the stock maf sensor or delete it and go with a SD tune?looks real good,i am painting mine black too,a low luster black like the stock one.
Old Mar 17, 2007 | 10:54 AM
ls1 jeff's Avatar
Im using the "243" heads with no milling so I didnt even check how the runners lined up with the ports. No port matching either. I used the stock maf.
I originally painted my FAST a gloss black, but I didnt like it so I changed it to a flat black(pics above). I think it looks great.
Old Mar 17, 2007 | 12:16 PM
Chris Campi's Avatar
nice setup.
I believe your CATCH can lines are not correct. Double check the setup. Keep me posted
Chris
Old Mar 17, 2007 | 12:31 PM
TheBlurLS1's Avatar
That's what she said...
That's pretty sweet! I've been wanting to paint my FAST 90 and finally found a color I like! Flat black is definatly my style!
What kind of primer/paint did you use? I'll probably hit mine with the same treatment.
Also, is that a new gasket between the two shells? Where'd you get it from?
Old Mar 17, 2007 | 06:17 PM
ls1 jeff's Avatar
Originally Posted by Chris Campi
nice setup.
Chris
Funny you should mention that. A good buddy strongly reccommended that I run the lines that way. So far so good. This is the NLP catch can if that matters. I just noticed, but the car in this thread is running his catch can lines the same way I am. Ive seen them done both ways.
http://forums.corvetteforum.com/show...&highlight=nlp
Old Mar 17, 2007 | 06:20 PM
ls1 jeff's Avatar
The paint is actually flat black primer. Its smooth to the touch and has a factory look to it.
All the gaskets are new...didnt want to take any chances. You can get everything directly from FAST. Just give em a call.
Old Mar 17, 2007 | 08:13 PM
matt94z's Avatar
Looks good man. Has a very sleeper look for all that POWER!
Old Mar 17, 2007 | 08:28 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I like that sleek paint job. Hard to tell if you ground down the FAST portion.
Old Mar 18, 2007 | 10:43 AM
ls1 jeff's Avatar
I shaved the wilson logo, but left the FAST alone. Im not fooling anyone with the way this car sounds.
Old Mar 18, 2007 | 11:24 PM
pdd's Avatar
pdd
looks great-wow what a clean engine bay
Old Mar 19, 2007 | 09:34 AM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
I agree.. smooth!!! i love the way my stock LS6 manifold looks b/c my car is black and matches!!!
Old Mar 19, 2007 | 09:36 AM
teke184's Avatar
what's the rest of the engine's setup??
Old Mar 19, 2007 | 02:04 PM
ls1 jeff's Avatar
The motor has Patriot cnc'd 243 heads with 2.02/1.57 valves. Im using the stock 64cc chamber and GM gaskets. The cam is 232/240 .595/.610 110.
