GMMG or Basani true duals?
Old May 25, 2007 | 09:55 AM
ONEBADASSWS6's Avatar
Go with the Bassani True duals. I've never heard a Y-pipe setup that sounds nearly as good as dual exhaust, 2 cylinder banks should have 2 exhaust pipes. Its just the way it as meant to be, Y-pipes are less than optimal for a number of reasons.
Even though the GMMG is louder, the Bassani more than makes up for it in overall sound, tone, power, and torque.
Old May 25, 2007 | 11:12 AM
Blakbird24's Avatar
Restricted User
Originally Posted by lsx24
What are you trying to say? Usually a good ypipe setup costs LESS than true duals...if you want to play you have to pay.
Weren't you the one telling me that GMMG is overpriced? And now you're saying that duals are more expensive?
Originally Posted by AKRA
P.S. Because of the X-pipe, I had to switch from the SLP Driveshaft Loop to the BMR.
See? Clearance issues. Not that this should turn anyone away from TDs but it's something to consider because you'll end up spending alot more than you planned, or if you had gone with a Y-setup.
Old May 25, 2007 | 11:16 AM
lsx24's Avatar
GMMG IS overpriced. And Bassani duals ARE more expensive. That has nothing to do with anything, lol.
Old May 26, 2007 | 05:45 AM
LS1speedy's Avatar
When you think about it GMMG is only $270 dollars more than a brand new slp loud mouth CB.
Add more to this post later
Old May 26, 2007 | 09:17 AM
2_wacko's Avatar
Theres a video of my gmmg with catted y pipe not that loud but I have no rasp.
Old May 26, 2007 | 10:51 AM
jag42420's Avatar
I went Bassani. Interior noise is comparable to stock, but outside is a bit louder. WOT is definitely louder, and big power gains.
Old Oct 21, 2007 | 10:07 AM
PureWS6's Avatar
What type of muffler comes with the bassani set up? Do they have multiple muffler options available? I want something annoying LOUD!
Old Oct 21, 2007 | 10:31 AM
jag42420's Avatar
It comes with a single muffler that is divided into two chambers, one for each pipe to go through. There are no muffler options. If you want it loud, lose the cats. If you want annoyingly loud, look at the TSP dumped kit.
Old Oct 21, 2007 | 05:06 PM
bene's Avatar
Trunion King
This is what bassani true duals sound like outside.
http://www.fquick.com/videos/1_4_mile_run__6/1795
Old Oct 21, 2007 | 05:48 PM
bene's Avatar
Trunion King
Originally Posted by jeffbab
What's this about having to switch from the SLP Driveshaft Loop to the BMR?
If you go with Bassani are you going to run into clearance issues? I figured it would be a simple bolt-in installation?
It is a simple bolt on. But I think the system might have some issues w/ DS loop. Here is what mine looks like under the car.
Here is my buddy's Y pipe set up and UMI T/A w/ DS loop.
Old Oct 21, 2007 | 06:53 PM
2_wacko's Avatar
GMMG good power, good clearace and great sound that why I run GMMG.
Old Oct 21, 2007 | 08:53 PM
  #32
mrr23's Avatar
Originally Posted by Pretyflywiteguy
which is louder? (decibel levels would be greatly appreciate) also, which gives the most power? and where can i buy the Basani kit?
TIA!
louder = GMMG
most power = never seen a comparison between the two. i did compare the borla adjustable to the bassani and picked up 15 rwhp with the bassani.
buy = http://vincihighperformance.com/fbod...t.html#EXHAUST
if you want to hear it on my cars, you know where i live.
Old Oct 21, 2007 | 10:32 PM
  #33
PureWS6's Avatar
http://www.fquick.com/videos/1/4_mile_run_#6/1795
Video not found in our database. Sorry.
It seems the video isn't working
Old Oct 22, 2007 | 12:11 PM
  #34
bene's Avatar
Trunion King
My bad. It's fixed now. There are more videos of the exhaust in my FQUICK link at my sig.
Old Oct 23, 2007 | 09:28 PM
  #35
PureWS6's Avatar
That sounds pretty sweet...what other mods do you have done?
Old Oct 23, 2007 | 09:53 PM
  #36
bene's Avatar
Trunion King
SW long tube headers, MTI lid, Free mods: FRA, P&P tb/by pass/bump stop, EFI tuned (wide band), Yank 3500, Hayden HD tranny cooler, GM 3.42 to replace the suck *** 2.73.
Old Oct 23, 2007 | 09:59 PM
  #37
LS1-NAVY's Avatar
i would pick gmmg. it sounds good
