Cutout: Worthless or not?
As a noise maker - it is quite effective.
For power, on my car which the exhaust is noted for being free-flowing.
I dynoed w/i 1-2 rwhp/tq with the cut-out open or closed.
I ended up cutting out my cut-out. Needed the ground clearance more than the noisemaker.
but hte beauty of a cutout is that they are only like $30. get one and just see what happens. if you dont gain much then cap it and move on.
I think a cutout would be a big mistake in this situation. Your catback is basically just straight pipes. The cutout could actually be a restriction in your system and will do nothing but cause more interior resonance. IMO, it'll hurt you more than help you in almost every situation.
unless its positioned correctly and same size diameter of new exhaust plumbing, ihave heard of/seen big cube motors with h/c/i picking up power with c/o
so imo they work
Agan, if you do add a cutout, it's going to hurt you when it's capped because it's going to put a kink in your exhaust flow. With it open, you may gain 2 or 3 rwhp up top, but you'll probably lose some torque down low. The longer exhaust tubes can actually help create a little more velocity down low, at least that's the way it feels for me.
A cutout, IMO, is just a "sound mod" when you already have a good performing catback, and in your case, all it's going to do is cause vibration and noise at cruising. If that's what you're looking for, go for it. My open cutout has been track proven to perform worse when open over my Corsa catback, but I run it open all the time because I'm 21 and love my car very loud and full of vibrations. Whatever floats your boat
I seemed to be 2 tenths or so slower with my cutout open in some testing today on my timing instrument. I dont have all the mods in my sign on my car currently. I figure the cutout might work good when the twin turbos are on the car. It is a fun mod though. I have had three and like this make the best..expensive but seems to work good and not rattle when closed like the other two qtp and dmh.
This one is a street pro.
Once I installed the heads/cam, it was a different story however. When I closed the cutout it felt significantly slower and less responsive. I then chucked the y setup in favor of true duals and a x pipe, and couldnt be happier. I have the sound and performance ALL the time.
