mids VS LTs
LTs are the way to go for power.
i dont want to loose low end, well i know you dont loose it it just gets moved up higher because of the scavvenging effect.
would i need a tune RIGHT after doing them?
Mids will work best with a high reving setup as they will scavenge better at higher rpms, however if they have 2.5" collectors they will be limiting on a high HP setup.
BUT and it's a big [size6]BUT!!![/size]
All of these are illegal in CA. Shorties are the only route and strictly speaking only CARB certified ones.
The trouble is shorties are almost pointless on a n/a setup. This is because it's not about flow but scavenging.
The stock manifolds will generally flow well enough for most n/a setups. And shorties don't scavenge within the Ls1 rpm range, so typically most will only see 5rwhp gain with them. This means a lot of money and hassle for small returns.
If you plan on boost then shorties work very well because they do out flow stock manifolds and a FI setup will make use of them.
You'd probably get away with the Pacesetter shorties (mids) as they don't move the cats, but to the letter of the law they are not legal unless CARB certified.
Just depends how much of a risk taker you are. Personally unless going FI I wouldn't bother with shorties, spend the money on something more worthwhile. But in CA you are up against it for an n/a setup.
Seriously consider nitrous, Procharger, bigger displacement (402, 408ci) or a 2003/4 Corba.
Also advising someone to go Lt's in CA is not really a sensible thing to do. It would be down to the individual to make the call on whether they are happy to run the risk of a fine, car impound or getting nicked.
Not to mention, as far as I know, there is only ONE set of mids for ls1, and those are MACs. Their deficit in the midrange has already been well documented.
