Header Help?!?!?!?
Old Mar 19, 2007 | 07:14 PM
FNQUIKWS6's Avatar
Default Header Help?!?!?!?
I just installed some pacesetter lt's and a ory. There a weird sound coming from the drivers side and I'm guessing its an exhaust leak?? kinda sounds like a spark plug knock,except louder, what could be causing this?? I have metal gaskets if that matters.
Old Mar 19, 2007 | 07:17 PM
Raise's Avatar
could be a slight exhaust leak. remember though, valvetrain noise will be significantly louder with headers because of the thinner tubing walls. so you may not have a leak at all. ls1s are noisy motors to begin with (lifters, injectors, piston slap) so you may just be hearing valvetrain noise that is just more pronounced now that u have headers. my $.02
Old Mar 19, 2007 | 07:19 PM
Tainted's Avatar
just to make sure, go back and tighten down all your bolts, make sure the plugs are all the way in and all your plug boots are on good
Old Mar 19, 2007 | 07:24 PM
FNQUIKWS6's Avatar
Holy **** that was fast!!! Performance wise the car feels fine, doesnt feel slower.
Maybe its just the headers, thanks Tainted.. i will go back and make sure the bolts are tight and plug wires are also. Man this web site kicks ***
Old Mar 19, 2007 | 07:35 PM
raymundojr's Avatar
Default checck this out
Try to check the K&N filters maybe its used up already that is why its producing unwanted noise.Also check out the treads,it could possibly be the answer.
Old Mar 19, 2007 | 07:42 PM
TheSecretFormula's Avatar
Mods ban this guy.
Old Mar 19, 2007 | 07:44 PM
FNQUIKWS6's Avatar
WTF is ray talkin about?? SPAMMER!!
Old Mar 19, 2007 | 07:46 PM
Tainted's Avatar
lmao thats more random than a midget ******* a horse
 Michael S. Palmer
Old Mar 19, 2007 | 07:49 PM
FNQUIKWS6's Avatar
or maybe its my windshield, all the bugs on it are causing serious wind resistance and thats the noise .. just needs a good cleaning
Old Mar 19, 2007 | 08:54 PM
jares99's Avatar
Just throwing this out your sure it isn't header ory y-pipe hitting floorboard or the k-member.
Old Mar 19, 2007 | 09:14 PM
FNQUIKWS6's Avatar
actually my y-pipe is hitting the floor, why does is do that?? do i need a bumpstop for the y??
Old Mar 19, 2007 | 09:17 PM
blkbird's Avatar
Polymounts will take care of that issue.
Old Mar 19, 2007 | 09:59 PM
98Camarod's Avatar
I was going to say it was hitting the floorboard. Thats what mine did. I couldnt get it to stop and just bought true duals from tsp. The bump stop hanger wouldnt mount correctly and didnt do anything. The only time it stopped is when I wedged a piece of rubber exhaust hanger in there. Once it melted it started banging again.
The knocking is most likely robbing you of performance because your knock sensor is picking up the vibrations/knock and retarding the timing.
