Exhaust Question guys, would this setup be restrictive?
Old 03-23-2007, 10:40 PM
92SilverSHO's Avatar
Default Exhaust Question guys, would this setup be restrictive?
ARH 1 3/4 race headers with ORY and stock catback with SLP OEM Dual dual muffler?
What do you think? Im figuring worst case i could add an ecutout.
thanks!
Old 03-23-2007, 10:58 PM
5_02ls1's Avatar
if it has the dual dual wouldnt you use an h or x pipe?
an hpipe or x with that setup woul flow really well
Old 03-24-2007, 01:10 AM
That's what she said...
TheBlurLS1's Avatar
The Dual/Dual muffler will flow awesome with that setup, and you'll be VERY pleased.
I have made back to back runs with my cutout closed (exhausting through my Dual/Dual), and with it open. This is on a ~400rwhp car, runs turned out identical. It actually feels faster when the cutout's closed.
Old 03-24-2007, 07:57 AM
Ragtop 99's Avatar
The restriction will be your stock I-pipe. I'd empty into a 3.5" I-pipe add your cutout and then neck down to the stock piping to gover the axle. You'll be quiet when just cruising and have no restriction when racing.
Get a good Y-pipe too.
Old 03-24-2007, 10:47 AM
im getting the matching ARH ypipe. Well when they put it on the dyno and if its not choking, then ill be ok. Worst case, add a cutout in the Ipipe. Thanks for the input guys, keep it coming!
Old 03-24-2007, 10:50 AM
10 Second Fun Car
jlrz28's Avatar
Sounds good. The slp dual dual has a little bigger I-pipe I believe than stock(2.5 or 3)?
