Odometer's frozen/speedo doesn't work
Old Mar 25, 2007 | 10:35 PM
greysteel_M6's Avatar
Default Odometer's frozen/speedo doesn't work
Wasn't sure where to put this but I just swapped out my clutch and now the speedo doesn't work and the odometer is frozen. I'm sure I plugged everything back in, any ideas as to what I screwed up?
Old Mar 25, 2007 | 11:08 PM
B's 95 Z28 A4's Avatar
Dude I'd double check on those wires, thats what it kind of sounds like. Don't remeber if
it on the tail shaft or not, thats were it is on my boys 5.0 and his **** dont work either.
good luck man
Old Mar 25, 2007 | 11:23 PM
Thanks, this comes at a real f'd off time cause I'm fixing to sell it.
Old Mar 25, 2007 | 11:27 PM
Ferocity02's Avatar
Definitely something wrong with the speed sensor, which happens to be located in the tranny which you removed to do the swap. If it's not unplugged, then check over the wiring and make sure it's not scuffed/shorted. It's possibly but not likely the sensor itself was damaged, although it would be the first time I've ever heard of that happening.
