Whats better? Tuned or Untuned headers
Old Mar 31, 2007 | 12:54 PM
1meantransam's Avatar
Default Whats better? Tuned or Untuned headers
hey i was wondering whats better for when i get my headers because i know tuned is more expensive but what is the real difference between tuned and untuned??
Old Mar 31, 2007 | 01:18 PM
Bump.
Old Mar 31, 2007 | 01:25 PM
bandit4's Avatar
I Beleive It Is The Air Flow Being Equal.
Old Mar 31, 2007 | 01:57 PM
but what would i be losing if i got untuned? a horse or two? any sound difference
Old Mar 31, 2007 | 02:44 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
about 25rwhp and proper a/f ratio.
Old Mar 31, 2007 | 03:42 PM
ReducedFat's Avatar
He's talking about equal length primaries, dude.
Old Mar 31, 2007 | 03:56 PM
bww3588's Avatar
as far as i know, SLP is the only LT's for the LS1 f-body that are tuned length. and the fitment/clearence sucks.
Old Mar 31, 2007 | 05:12 PM
TheBlurLS1's Avatar
That's what she said...
Buy based on material/fitment/cost, not tuned or untuned. Nearly all 1-3/4" headers make the same power, "tuned" or "not tuned". The "tuned" portion deals with the way the exhaust pulses hit the collector and promote correct scavenging. If you're in a limited motor racing class, have tons of room under the hood, and are looking for that extra hint of possible HP, tuned headers might be the right choice. Not the case for F-bodies.
Re-read post dude!
Old Mar 31, 2007 | 05:27 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
+1.........I have em!!
Old Mar 31, 2007 | 07:16 PM
Hard Core Z28's Avatar
A true tuned header would be a header that has a certain primary length,diameter that matches a certain combo. Once you change that combo it isnt tuned to the car anymore. And im not refering to PCM tuning.
Old Apr 1, 2007 | 01:20 AM
Sudz's Avatar
i dont understand the whole tuned length theory, The cylinders dont fire at the same time so whats a tuned length going to do anyways ya know?
Old Apr 1, 2007 | 01:27 AM
TheBlurLS1's Avatar
It uses the venturi principle. Fluid flowing through an area causes a low pressure outside the stream, sort of like a carb. Air flowing past the jet causes fuel to be sucked up through the jet and mixed with the stream. This means the opening of the jet is at a lower pressure than the fuel in the bowl. This difference in pressure is the motive force for the fluid movement.
Ever stood in the shower under the water, then stepped outside of the water? As the water around you stops flowing down your body and hauls *** straight to the floor, the shower curtain sucks in toward you. Step back into the stream and it subsides. Try it in the morning.
In headers case, the exhaust coming out of one primary into the collector is supossed to create a lower pressure in the other primaries. If you make them the right length, you'll have pulses hitting the collector at equally spaced times.
Old Apr 1, 2007 | 03:40 PM
greatskiiiier's Avatar
Tune it.. 20 RWHP and it wont be running 100%
Old Apr 1, 2007 | 03:48 PM
8a8mfh's Avatar
Half this thread is talking about tuning the VCM and half is refering to equal length headers
Old Apr 1, 2007 | 03:50 PM
brad8266's Avatar
he was talking about tuned header ports, lol. Anyway even with a PCm tune 25HP is highly unlikely.
Old Apr 1, 2007 | 03:52 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
EDELBROCKS are tuned...Equal Length.
Old Apr 1, 2007 | 07:39 PM
BLK02TA's Avatar
Old Apr 1, 2007 | 08:32 PM
Yeah, thats what my buddy has and he has trouble getting in the car without scraping lol
Yeah lol i noticed that i just want to know headers alone
Old Apr 1, 2007 | 08:33 PM
GTObsessor's Avatar
You sure? I got a buddy that wants that "smooth sound" tuned headers give... anyone here know if this is still possible with tuned headers (if Edelbrocks are indeed tuned length headers) and a Y-pipe setup?
Old Apr 2, 2007 | 03:28 PM
is there any REAL sound difference between tuned and untuned headers
