Kook's 1 3/4", stepped, or 1 7/8" Header Help!
Tech Resident
Originally Posted by 99blancoSS
Heres something that doesnt happen very often taco is wrong.
The 1 3/4's and 1 7/8's are the same price.
I'm running 1 3/4 kooks lt stainless steal. love them have had them on for alittle 2 yrs now and still no rust, however do have some discoloration due to high heat from exhaust just a couple of inches from heads but, thats expected. go with 1 3/4 for best fit.
Originally Posted by ChocoTaco369
who cares? you're still going through a harder install for headers that likely won't perform any better. i've heard many a nightmare installing 1 7/8 headers, even the kooks.
Tech Resident
Well you can either be accurate or you can be Taco I guess. I just installed the stepped and they were easier than the last 1 3/4 headers I installed.
you wish you were me. i guess only i'm that lucky. me >> you
mm hmm. and did you install kooks 1 3/4 the last time? otherwise, you're mixing and matching brands and designs. you really can't do that to gauge install difficulty. also, this was your second time around doing headers.
As far as removing the stock stuff use penetrating oil and you wont have trouble.
Your whole argument was to not use the 1 7/8's because they dont do anything and cost more than the 1 3/4's. So I corrected you on that. They are the same price as the 1 3/4's , its the stepped that cost more.(and for reason). Now your going down a different path to not be wrong about what you've said and no matter what your still wrong Just give it up.
Tech Resident
The first set was Stainless Works and they were a PIA to get in. The Kooks were by far a lot easier and it had nothing to do with the fact that I installed the SW's already. They're just a better fit so install is a lot easier.
1 3/4 > 1 7/8. unless you're running a stroker or big boost, i see no point.
