Throttle Body Question
Old Apr 2, 2007 | 04:56 PM
RYNO_Z's Avatar
Default Throttle Body Question
I have a throttle body sitting in my house off an 02 TA. Am I correct in saying that the only thing I have to do to make it work on my 98 is replace the throttle cam due to the difference in throttle cable lengths? If this is correct, where would I pick this up from?
I am wondering because I would like to make a run at porting the extra one myself and have the other as a spare. Let me know guys.
TIA
-RYAN
Old Apr 2, 2007 | 05:08 PM
Bo White's Avatar
Correct, just swap the throttle shaft out and youl be good
Old Apr 2, 2007 | 05:18 PM
TheBlurLS1's Avatar
That's what she said...
You'll just have to take your stocker out and swap it over. You will port it with the blade/shaft out, so you won't have to worry about damaging it.
You can also pull the coolant tubes out of the throttle body for a little cleaner look. This is considering you have done the TB bypass mod. It's a PITA to get them moving, but they are just pressed in. Twist and shout and they will pop out.
