amw pcv routing?
Thanks for the response, btw!
Easy to see if you follow this picture
http://www.ls1howto.com/howto/geniii..._installed.jpg
You can't drain the PCV but you can drain the Can...!? I think either way will work... (i guess the debate and the research is on ! LOL)
According to AMW, we have the catch can right in that it goes IN to the top and OUT the side.
Another school of thought is to reverse that so you're pulling out the top through the screen. I think that's how rapidmotorsports has their catch can setup.
Which of the three holes in the block did you use?
Thanks in advance.
JB
I turned around valve boot, put it on the valley nipple, ran a hose to the top of the can, out the bottom with another hose, to a coupler, to the TB grommet.
I would think that it would HAVE to hit the top of the can first, so the steel filter would change the spray to drops that fall to the bottom of the can and would have to run up the can's sluice before exiting into the TB.
Here's a bender... wouldn't it be optimal to have 1 valve on each side??????
I agree. Here's the thread with it the other way. In defense of the deigner, it may have to be that way with THAT catch can.
https://ls1tech.com/forums/showthrea...=pcv+direction
https://ls1tech.com/forums/showthrea...ight=pcv+valve
Also in reference to the guy that asked about the bracket, I have the bracket that came with the AMW can and have it installed on the driver's side in front of the fuse box next to the radiator. The hose runs are long obviosuly and routed under the MAF.
I like your idea Steve of another PCV valve after it leaves the can, but I can say with my setup I get no oil in the intake.
my head hurts...
