EWPs? Other than Mezire?
Old Apr 7, 2007 | 11:48 AM
bayer-z28's Avatar
Default EWPs? Other than Mezire?
??? All I can seem to find for EWP's for our car are Mezire.
I checked TSP and LS1 Speed.
Old Apr 7, 2007 | 11:50 AM
MeentSS02's Avatar
Kleeborp the Moderator™
I've not seen any others.
Old Apr 7, 2007 | 11:59 AM
bayer-z28's Avatar
damn. we put one on -=Modified=-'s car, we had to grind the TB cable bracket down to get it to clear. I heard the MEzire's don't flow that great... -Any truth to that?
Old Apr 7, 2007 | 12:14 PM
MeentSS02's Avatar
That's pretty common...I had to do the same. Not sure where you heard that rumor...probably from someone that didn't want to spend the coin to buy one.
Old Apr 7, 2007 | 12:56 PM
cowboysfan's Avatar
I didn't know the Tb cable bracket is attached to the "Electric Water Pump"?
Moraso, I think makes them too.
Old Apr 7, 2007 | 01:27 PM
MeentSS02's Avatar
The throttle cable cam on the throttle body contacts it...the bottom of the cam interferes with the top of the water pump. It requires minimal grinding to clear it...something that has been well known and documented for quite some time (check out ls1howto.com for more info).
Old Apr 7, 2007 | 03:20 PM
black01_WS6's Avatar
Evans makes one, but you HAVE to run their coolent.
