I'm about fed up w/ my Kooks headers & GMMG catback
I've been running the same combo (Kooks LTs/ORY and GMMG) for a good while now and mine has never hit the bottom of the floor, or vibrated. Still have the stock motor and trans mounts as well.
Odd that it's giving you guys that much trouble...I worried about it when I put them in, but so far they've been great.
Originally Posted by jimmypop13
to keep the i-pipe from hitting, try to pull the gmmg apart a little where the pipes meet over the axle and tighten the clamp back down. Also, check the rubber in the exhaust hangers. It could be worn, causing the catback to sit to low and that could cause the pipe to hit the axle.
As for the y-pipe, get some poly motor mounts. It will keep the exhaust from moving much when you are driving. Also, if the y-pipe is hitting under your seat and the mufflex hanger doesn't work, the heater hose method is cheap and proven. You just need hose, exhaust wrap, and some clamps. Here's a pic:
-Chris
-Chris
I'm going to wait until I get the bracket in and see where we are after that.
Thanks. The only thing I can see the poly mounts being good for is keeping the exhaust more still when cranking it up. That still does nothing for getting it off the bottom of the car all of the time.
The shop that did mine just put a rubber piece of tube. Not like how jimmypop's heater tube is, but similar. And so far I don't have any problems with it hitting under my car. Although the only thing is that I have Pacesetters, but they still go right up against the underside of my car.
Have you tried to loosen both LTs, the Y-pipe, and the rest of the exhaust and tried to readjust it? It sounds like a lot to do but unless you loosed most (if not all of the exhaust) I've found that it could cause some binding and not allow full adjustment.
I know that QTP makes their header flange holes a little bit to allow for a little additional up-and-down movement. If you loosen the entire exhaust, and see if you and adjust the collectors a little further down, you may just get enough clearance.
Good luck. Not even LT or CB fits every car perfect. You've got good quality stuff, and it just may take a little more TLC than other cars. I know mine has. ;D
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
-Chris
-Chris
#32
Do you have subframe connectors and if so were they welded in correctly with the frame loaded when installed?
There is easily enough twist in the frame to allow for a 1/2 to 3/4 clearance gone missing if the sbf's weren't installed correctly.
#33
#37
Or you could trade headers with me + a little cash. I have a set of MACs and the Y pipe. I even have the block off plates for EGR and AIR. maybe they wouldn't be as prone to hitting or rubbing?
#38
Originally Posted by DANSBIRD
I have no idea what that is
I'm surprised you're having problems with your Kooks system. They have a reputation for being a good fitting system. I had some banging on mine, but it was remedied by installing poly motor mounts.
If your system is riding against the bottom of the car, the motor mounts might not help. OTOH, I find it hard to believe that the system can not be tweaked to a better fit. I would call George at Kooks and ask for his advise. I've worked with him before, he's a helpful guy.
Good luck.
#39
I have FLPs, that is why there is a v-band clamp. It was impossible to adjust them without having the y-pipe hit the floor there, that is why I did the heater hose. It may be the same thing that guy above did to his old truck but it wasn't a big deal to me as no one else will see it, i still have great gound clearance, and it only took a few minutes to solve the problem this way. If you look at the last clamp in my pic, it is torn apart and there is a dent in the y-pipe right there. This pic was taken after I was in a wreck and I'm guessing the curb tore it up like that! I'm hopefully getting a new trans am this weekend!
#40
the motor mounts would keep the motor still while goin WOT causing the motor to trq up and the exhaust bumping the floor.. i had this problem when i put a ory on my manifolds..im sure that y pipe is every adjustable youll prolly have to get under there and loosen all the clamps and adjust it to where its not bumping a thing..not to bash someone elses work but didnt you pay someone to install this? would you check that while you installed it to make sure the fitment and is clear of the body..like they say on horsepower tv " when installing an new exhaust system keep all the clamps loose so you can check for clearance around moving parts, hoses and the body" but the cats on there so like puting 10lbs of shyt in a 5lbs bag..hell you outta see my tsp y pipe..it dont bang the floor but drags the ground every where. pullin out of the driveway.. im suprised it dont hit reflectors on the road lol...
the last i herd you where happy with the new exhaust..
hope everything works out man.
