need part numbers
Old Apr 9, 2007 | 02:11 PM
shifty`'s Avatar
Question need part numbers
Just curious - I am fabbing up new, longer, modified battery cables. I have the actual wire already, but I want to use the original GM 'ring terminal' connectors for the starter, alternator and master ground (in front of the starter. I went to Napa and hunted their catalog, but couldn't find the master ground ring terminal, nor the special ring terminal used on the starter.
Is this something available out there?
If not, does anyone have the opening size for these three ring terminals handy so I can go buy generic ones?
I have the part number for the actual battery cables already, but I am just looking for OEM replacement ends. I know this probably sounds ****, but I like keeping things stock in appearance
Old Apr 10, 2007 | 09:54 AM
shifty`'s Avatar
ttt
not expecting anything, but ... will give it another shot. i have more luck getting part numbers for crap on my VW GTI than on any GM product i've ever owned. still find that a little sad (VW has a part # for everything on the car )
Old Apr 11, 2007 | 12:43 PM
shifty`'s Avatar
Ok, one last bump. Found a lot of stuff at www.currentperformance.com , but the ring terminals are too small AWG for the wire I'm using.
